Can anyone recommendsome performance shops in South Louisiana. I'm looking to do some work on my 06 RKC such as porting my stock heads and boring out my cylinders to 95 ci.
The Harley shop in Baton Rouge has a couple of very good engine builders. They built my 100hp/106tq 95" motor. The motor has 10,000 miles on it with no problems.
Mike Cat's in Kenner, LA is also a good place for motor work.
I don't know much aboutshops in the Lafayette area nearer to you.
Thanks for the comeback ! I'm just looking to get the machining done for some of the components. I will be doing the tearing down and rebuilding myself.
I just PM'd you with some info. Call me if you need more help. In addition, Tony at HD of BR is the senior guru in that shop and can probably also help. He's like a god, however, and getting hold to him directly may be difficult. Kind of like calling the governor, you know.
