No response when pulling diagnostic codes
Old Feb 21, 2016 | 11:04 AM
just plain john's Avatar
just plain john
Default No response when pulling diagnostic codes
I'm chasing an intermittent no crank condition after changing the top clamp on my 05 FLHTC. I tried to pull the diagnostics on the ecm and get a 'no rSP' which I assume means no response. When pulling the other codes I get a 'none', and again I assume that it's reading those codes but not the ones from the ecm. By a intermittent crank condition I mean when the ignition is switched on, the fuel pump doesn't come on, and the starter button doesn't work. If the pump does come on the starter button will spin the motor over but it won't start. It would seem that the diagnostic circuit for the ecm is open. I can't find any information on the diagnostic circuit in my manual. Has anyone else experienced this?
Old Feb 21, 2016 | 11:06 AM
Vernal's Avatar
Vernal
You will get no response if the kill switch is off.
Old Feb 21, 2016 | 11:09 AM
just plain john
Kill switch is set to run
Old Feb 21, 2016 | 11:13 AM
just plain john
I've checked and rechecked my connectors, looked at the wiring at the starter and kill switches and it's not pinched, verified voltage through the ignition switch, and checked fuses for the fuel pump circuit. I'm stumped.
Old Feb 21, 2016 | 11:32 AM
Vernal's Avatar
Vernal
Ignition fuse supplies 12V to kill switch. When on it supplies 12V to start switch and to the coil of the system relay. System relay when energized supplies 12V to fuel pump fuse.
Recheck all your connectors and make sure your battery is charged and all cables, including grounds are clean and tight.
Good luck
Bill
Old Feb 21, 2016 | 10:41 PM
Vernal's Avatar
Vernal
You say you replaced the top clamp, so you had the ignition switch out. Do you think it could be the ignition switch causing the problem?
Greezey Rider
Jul 6, 2016 09:31 PM
just plain john
Feb 20, 2016 06:58 PM
Dharn55
Electrical/Lighting/Alarm
Jul 13, 2015 08:42 PM
Bo_Jangles
Nov 19, 2011 08:19 AM
Ohio UC
Apr 18, 2011 09:54 PM
