My 07 Road King Custom chirps when I initially get on the throttle. Took it to the dealer and they said they didn't know what it was. I asked if was the belt and they said no. Let me know when you figure it out. I was thinking clutch.
My Exhaust mount rubber bushings squeek and chirp like crazy, I have tried everything from spray on silicone to dry graphite. and Ideas on something that might work for more than 15 minutes ? i guess I never thought about buying new ones in case these are worn out and sloppy.
ORIGINAL: duelly95
You mean the rubber pieces in the brackets out at the end of the mufflers under the bags?
I stick a penny or two inbetween the rubber and the metal bracket. Keeps it from chirping at idle.
Yeah what you said, them are Da ones, so a penny will stay in there and not fall out? I would hate to have some poor SOB behind me get a penny in the face. thanks for the 2 cents worth, hahahaha one for each side,
To stop the muffler squeek I took the bracket off and put a thick layer of silicone grease on the top of it and reinserted it. I got the one ounce contaier of grease from Home Depot in the faucet repair parts section.
WD40 is for amateurs.
