My first dyno tune
Old Feb 24, 2016 | 07:02 PM
OldBill's Avatar
OldBill
Default My first dyno tune
My 2012 FLHTK was pinging something awful under load right in my cruising range (2500-3000 rpm) so I took it to Stick Engineering in Apache Junction, Arizona. Dave spent the morning on the dyno dialing in the tune, and all of the pinging is gone. As a bonus, I picked up 3 hp and a little more torque, too. I would highly recommend these guys for great work at a fair price.
Old Feb 24, 2016 | 09:53 PM
vistavette's Avatar
vistavette
Any work done to the bike (tuner, cams, exhaust...)? If you don't mind telling us, what did they charge you?
Old Feb 24, 2016 | 11:11 PM
RG Pilot's Avatar
RG Pilot
3 HP? I bet it's more than that.
Old Feb 25, 2016 | 10:09 AM
OldBill's Avatar
OldBill
My bike has the Fuel Moto 2-1-2 header, E-series mufflers, air cleaner kit and a Power Vision tuner with a map that Fuel Moto provided. Stock cams. It ran strong except for the pinging. Stick Engineering charges $75/hour, and they were done in under 3 hours. The first pull on the dyno was 75.93 hp/96.19 torque and the final was 79.16 hp/ 98.34 torque. Runs perfect with zero pinging. I am very pleased with the result.
Old Feb 25, 2016 | 10:27 AM
2013_FLHTK's Avatar
2013_FLHTK
This is my first EFI motorcycle. Our bikes require a great tune to run correctly not like the carb days when a mikuni flatside seem to work on everything. Stock my bike pinged like crazy not to mention the lack of performance. Stage 1 and a dyno tune by the dealer helped a lot but I still have ping when trying to maintain speed in fifth and sixth from 2700 rpm and up. No ping when I accelerate. Going to Rob's Dyno in Gardner, Massachusetts when the weather breaks to get it done right.
Old Feb 25, 2016 | 10:42 AM
Uncle Peepers's Avatar
Uncle Peepers
Thanks for the tip. I live near AJ, and I think I'll pay them a visit just to check them out.
Old Feb 25, 2016 | 11:25 AM
OldBill's Avatar
OldBill
They are on Superstition Blvd at Ironwood
Old Feb 25, 2016 | 02:17 PM
jt metal's Avatar
jt metal
I am very surprised. Sounds like fuelmoto had that bike dialed in. Except for the pinging.
Wondering if you have some bad fuel? What octane?
Old Feb 25, 2016 | 06:02 PM
OldBill's Avatar
OldBill
Fuel Moto didn't tune the bike, they just sent a map with the Power Vision. I just moved from Oregon to Arizona. In Oregon I was running 93 octane pure gas, but down here in AZ they only have ethanol crap gas. I always run premium and it ran well in Oregon.
Old Feb 25, 2016 | 06:05 PM
albngore's Avatar
albngore
Default Dyno tuning is just nonsense, if . . .
If you have one of the fuel/air management systems (I thing they are called this) such as Dynojet's, FuelMoto's, or others,--then, knowing your modifications from stock will give you a MAP sufficient for anyone who is not a fractional horsepower-power advance freak. If you have pinging, there is either something wrong with the MAP you loaded or the fuel you use--or, of course, the way the modifications were installed.
The entire dynomometer industry is based upon fools paying hundreds for something that won't make a rat's *** worth of difference if the MAP is even CLOSE to correct. Perhaps if you are a racer there might be a marginal benefit. Anybody on a Touring cycle is just damn stupid to go this route.
