So Rocker - where did you set yours with the HD springs? I get it'll be different based on weight, ride solo/2 up, and the tour pak load. I really want to make these work after unloading $600 for them. Right now I have the air shocks back on after changing to 10wt oil in them.
I have 3 1/2 lines showing at the top of the shock. I have them set on the stiff side, I'd rather be prepared for The Bump and put up with a little harsher ride.
__________________________________________________ ____ For ROCKOUT information & purchasing please click the links below...
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
