Brake Turn Signal Light Question
Old May 13, 2007 | 10:53 PM
ezlife's Avatar
ezlife
Default Brake Turn Signal Light Question
Anyone know what I can use to turn my turn signal taillights into running/brake lights also? Can't use HD part#69461-06 because I don't believe it's compatiable withn the new relo kit I installed and the red lenses included are flat for stock bar light.
Thanks guys.
Here's pic of the one I want to add function to:
Old May 13, 2007 | 10:58 PM
Retired_Ted's Avatar
Retired_Ted
Default RE: Brake Turn Signal Light Question
Click >>>HERE<<<. These folks are great to deal with and have just about anything you'd want electronically.
Old May 13, 2007 | 11:48 PM
soos's Avatar
soos
ORIGINAL: ezlife
Thanks guys.
Check out HD# 69462-06, it is in the Softail section, pg 380 of the 07 accessories catalog. The inline module is the same for all models, just the lenses are different.
Old May 14, 2007 | 12:05 AM
jrudicel's Avatar
jrudicel
Thats what i used...for a softail Deuce I believe....worked on my 06 StreetGlide. Modules are the same, just get the kit with the bullet lenses you need..
Old May 14, 2007 | 12:10 AM
the_icemAN's Avatar
the_icemAN
Yeah... that kit should be fine for different lights. Difference is you can't use the red lenses that come with it. You will probably want to replace the amber with red lenses on the lights you put on the rear.
Old May 14, 2007 | 04:54 AM
PapaTravis's Avatar
PapaTravis
Funny thing, I have found parts for my '05 rk custom in the softail section. I wanted to relocate my turn signals from the handlebars (now 18" apes) to below the passing lamps I installed when i got the bike. Went into the service department and they wanted me to buy an all new light bar. [:@]Said there wasn't a part to do it on touring bikes.I did a little research of my own. Both on the web and in my parts manual. I was thumbing through the softail section and found a part to do this on a softail. Bought the part, and installed it. Works fantastic, just like it should. The moral being, just because it isn't specifically designed for touring bikes, doesn't mean you can't find something that will work.
WOW, I just went to the MoCo site to get the part #. Says the same part I ordered is $98.95. I paid just $59.95 for the part just a month ago. WTF is up with that?
Old May 14, 2007 | 06:23 AM
ricaroo's Avatar
ricaroo
you can by the HD in-line module separate, its a little cheaper if you don't need the lenses. just ask at the parts counter.
Old May 16, 2007 | 01:28 AM
levi2005's Avatar
levi2005
Stage I
i just bought the part for my 98 ultra to do the same thing ...it says to splice the blue wire from the brake lite relay to the two orange wires from the insterment curcuit...i'm not to sure on the blue wire ,,anyone know?
Old May 16, 2007 | 01:32 AM
wesd41's Avatar
wesd41
ORIGINAL: PapaTravis
MoCo must've found out it works on touring bikes, too, so now it's twice as valuable.
Old May 16, 2007 | 01:42 AM
gman's Avatar
gman
i used the HD plu-in module and bought clear lenses. used the factory amber bulbson the front, and searched and found red bulbs on the net for the rear.
[IMG]local://upfiles/12616/1CC456B632F7410B838E3882CE5B2C3F.jpg[/IMG]
[IMG]local://upfiles/12616/0200A96C0D2B4ADFB7EEF7AB391E6FF8.jpg[/IMG]
