PLEASE HELP!!! What is going on?!?
Old Feb 28, 2016 | 06:24 PM
m_mcdonnell314's Avatar
m_mcdonnell314
I believe it was from over tightening of the bolts
Old Feb 28, 2016 | 07:02 PM
Vernal's Avatar
Vernal
Solid or Hydraulic lifters?
If Hydraulic - Check the "Caution" at step 9:
http://www.harley-davidson.com/en_US...ts/-J02268.pdf
Old Feb 28, 2016 | 08:37 PM
batman.'s Avatar
batman.
Weak battery.
Batman
Old Feb 28, 2016 | 09:44 PM
Blackjack1's Avatar
Blackjack1
Not sure on a bike but had a very similar situation on a jeep conversion to a V8. Turns out the motor needed to be grounded. If I slightly depressed the clutch it would run perfectly, otherwise it sounded like you describe. Depressing the clutch grounded the motor. Got to be something like this or timing, can't think of much else that would cause the behavior you describe.
Old Feb 28, 2016 | 09:56 PM
QC's Avatar
QC
Got the cam timing right?
Old Feb 28, 2016 | 10:22 PM
Bingee's Avatar
Bingee
Did you reverse the plug wires maybe?
Old Feb 29, 2016 | 07:53 AM
m_mcdonnell314
Cam timing is done right, made sure I did it correctly when I was in the cam chest. Plug wires are in the correct sequence. I'm going to adjust the pushrods again when I have free time this week. It all looks like that's the reason
Old Feb 29, 2016 | 08:10 AM
lp's Avatar
lp
Do a compression test real quick. That will tell you the condition of your valves, timing, etc. Also check for an intake leak by spraying WD-40 around the intake-to-head flanges while the bike is running.
Old Feb 29, 2016 | 08:50 AM
rusty289's Avatar
rusty289
My thought was timing, being off one tooth on the cams would do it.
What about your tuner? What do you have? Did you download a new map?
Old Feb 29, 2016 | 10:36 AM
Vernal's Avatar
Vernal
If I'm reading this right, the 95 BB kit was installed and the bike ran fine.
Rocker Boxes cracked so OP swapped out Boxes and installed a six speed Tranny. Now it runs poorly.
What happened between running good and now?
Fuel tank removed to get at Boxes?
Push-rod Adjustment
Could VSS cause a problem?
