Super excited I just ordered fuel Moto 107 kit with level B heads. I currently have woods 555 cams and I decided to up grade to 777 cams. This is going in a 2009 road glide. For those who have already done this do you have any suggestions?
I already have a SE heavy clutch spring, and VH power duels with monster rounds. I do have a set of riehnhart mufflers I could use too. I know the riehnharts are better flowing then the VH mufflers.
Can't wait to get it put back together and try it out.
You will love it, i just got mine back this week. I added the AIM clutch piece and ended up dropping the cash for the Jackpot 2 into 1 pipe. I think i love the pipe more then anything sound and quality of the pipe is second to none. My bike really feels alive now. The power is perfect. They sent me a map that was pretty close and after one auto tune session i am already happy. I will auto tune again when its broken in, but thinking i am not going to dyno. Although i posted another thread wondering what peoples fuel mileage is, because my first tank of gas was low. But i was auto tuning and back and forth on the throttle for the full hour.
Ditch the SE Spring and go with the Aim VPC (VP95LT). You'll thank me for it later.
OP: I have the exact set up that you'll have, and I too went on the cheap on bought the heavy duty spring. I FULLY endorse what Bates posted above. Within three months the increased tension broke my clutch cable, and caused extensive wear in the clutch lever area.
Do yourself a favor.....make an ash tray out of that heavy duty spring, and install a VPC. Thank both of us later!
my suggestion is to skip the se heavy duty spring. spend the extra couple bills and get the aim vpc.
I didn't when I did mine. the heavier spring really made it a bear to do 'friction zone' clutching. I know a couple of folks have also noticed increased wear in other areas (clutch perch, cable, etc) from the increased effort needed. I didn't notice any, but I changed mine out to the vpc after only a couple of months.
With an 09 you'll need a heavier spring. The stock spring is too soft even with a Vpc. Get a 340lb aim spring, it's lighter than a se spring and with the Vpc it'll hold almost anything you'll throw at it. It pulls pretty easy.
