S&S 124 for touring?
Old Mar 9, 2016 | 07:43 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
from s&s the 124LC for better dependability and longer engine life with less chance of detonation, sounds like what the op was looking for. add more power from the higher compression and lose the dependability of the rest of the driveline.
Old Mar 9, 2016 | 09:42 PM
bigskyroadglide's Avatar
bigskyroadglide
Originally Posted by IdahoHacker
Not that this is why anybody buys a 120, but what kind of mileage are you getting?
Under 80, between 36-38. Over 80, about 30. Tuned for max power.
I am currently adapting my tune with wide band sensors and auto tune to see if I can improve FE. I'm not expecting much since it's difficult to stay under 80.
Old Mar 9, 2016 | 10:07 PM
IdahoHacker's Avatar
IdahoHacker
That's actually pretty darn reasonable.
I've been talking to the most experienced tuner that I know, (fantasizing about going to a .585 cam...) and what the impact on mileage might be. Obviously, the biggest influence is your right hand, but aside from that:
It's very, very possible to take a look at the VE tables in the range where you do most of your cruising, for example 15%-20% throttle and perhaps 2,800-3,200 rpm, and ever so slightly go a bit leaner in that range. That way you get decent mileage at cruising speeds, but when you nail it you still get full power from 3,500 to redline.
Old Mar 9, 2016 | 10:09 PM
IdahoHacker
With a full stage 1 if I stay at a steady 65-70 mph I can flirt with 45, but even spending a bit of time at 75-80 I can still stay over 40.
Old Mar 9, 2016 | 11:15 PM
Fishrrman's Avatar
Fishrrman
I'm gonna sound like a party pooper, but if I was planning on doing numerous long-distance trips on a new bike, I would leave the engine essentially "un-opened" (not including mufflers, a de-cat, tuner, perhaps an air cleaner) and essentially "un-messed-with" inside.
You'll probably get much more longevity and reliability out of it that way.
My Road Glide (an '07 that I bought with 7,500 miles in 2011) just turned 65,000 today, and all the engine has ever needed was fluid changes...
Old Mar 10, 2016 | 05:38 AM
grbrown's Avatar
grbrown
Red face
Admittedly it was several years ago, in 2008 and for an Evo, when I really wanted an S&S 124" for my Glide, but ended up being persuaded against it. There was only model available then, the high CR version, which I was assured was not a good touring engine, especially if riding 2-up. I 'made do' with a 107". If I was in the market for a big motor today I would have no hesitation in chosing a 124LC.
There is of course the S&S 143", for those in need of a little extra!
Old Mar 10, 2016 | 07:24 AM
msocko3's Avatar
msocko3
I'd do the 124LC also in a touring bike, especially if you go to areas where fuel quality is sketchy. I've been places where 87 octane was the only thing that could be had. I know my present 120 doesn't like 87 octane, it'll ping and kick back when starting something awful. I learned this when I mistakenly put 87 in the tank, I couldn't fix it with octane booster, had to drain the tank and replace the fuel.
Old Mar 10, 2016 | 07:40 AM
hd_rolling's Avatar
hd_rolling
Some people are just internally wired to need more performance than a stage one engine can provide.
If you don't understand, your not one of those people.
I'd say as long as your engine is properly installed, broken in and dyno tuned you will have no issues. And chances are if you can afford to install an S&S124 than you can afford to pay to have it fixed if you have any issues.
If you can't, you might want to stay with a stage one with warranty.
If it was me and I had an S&S dealer/installer close by, I'd go with the 124 no question.
Old Mar 10, 2016 | 08:20 AM
MatteGlide15's Avatar
MatteGlide15
This is "Amurica" dammit..... We wanna have our cake and eat it too!!!
Old Mar 10, 2016 | 12:35 PM
oakmossy's Avatar
oakmossy
go for the Gold. Luv the look of the S&S engines.
