2012 passing lamps and switch
Old Mar 14, 2016 | 07:14 PM
lospuerco's Avatar
lospuerco
5th Gear
Default 2012 passing lamps and switch
Hi there, just fired up the beast for the first time this year, and I noticed my passing lamps will not turn on. Also the lamp switch does not illuminate, nor any other button on there, Ie cruise. Any thoughts???
Also the ABS light keeps flashing. have not ridden it yet this, still too much ice in the back lane.
Thanks for any info.
Old Mar 14, 2016 | 07:18 PM
HDJIM1158's Avatar
HDJIM1158
My ABS flashes until I hit the brakes a time or two. I would check the fuse for the passing lamps.
Be Safe JIM
Old Mar 14, 2016 | 07:56 PM
Vernal's Avatar
Vernal
ABS will flash until you reach 3 mph. Is your high beam on, passing lamps are powered by the low beam.
Old Mar 14, 2016 | 08:28 PM
lospuerco's Avatar
lospuerco
5th Gear
No High beams off. also no indicator light on the lamps switch or the cruise switch. will try to find the fuse. once i find my fuse tester. LOL 5 months of winter and i can't remember where I put anything.
Thanks
Old Mar 14, 2016 | 08:47 PM
Vernal's Avatar
Vernal
If your headlight is working then there should be power to the switch. Once you find your meter check that first If no power maybe one of the connectors is loose.
If power is present check your ground.
Good Luck
Spikehorn
Jul 2, 2018 11:35 AM
exWinger
Jun 1, 2015 03:38 PM
Mimo951
Sep 1, 2012 02:24 PM
SteveinNKC
Oct 25, 2010 09:19 AM
neonhomer
Oct 25, 2008 10:22 PM
