Thermostat Replacement
Old Mar 15, 2016 | 09:31 PM
josame's Avatar
josame
Vernal, are you talking an owners manual or service manual? I don't see a service manual on the Harley site. Can you tell me where to get one?
Thanks.
Old Jul 5, 2018 | 08:30 PM
junior70's Avatar
junior70
Default Coolant Level
Originally Posted by bowhunter97
Here's how just in case:
Fill system through filler neck until coolant is visible. Allow
coolant to bleed down for a few seconds and repeat.
Turn Ignition switch ON. Do not start engine.
Turn throttle to greater than 50 percent and hold for at least 3 seconds.
Coolant pump and fans will start.
Release throttle.
As the pump runs, continue to add coolant until filler neck remains topped off.
NOTE
Unlike operational mode, the pump and fans continue to run in bleed mode until ignition is turned off.
So I got the HI Temp and CEL and swapped out Coolant Temp Sensor and Water Pump. When I changed Water Pump I also removed the Thermostat. My coolant jug did NOT go down any!!!! I recovered about 12 oz for coolant and cleaned up a few more. Do you think I have a blockage, my bike is still throwing the same codes
silverbullitt
2014-2024 Touring Models
17
Feb 17, 2014 09:26 PM
Todd7446
Feb 26, 2012 09:27 AM
traveler
Apr 26, 2011 10:32 PM
Big Sled
Oct 5, 2006 11:43 AM
radrex
Aug 4, 2006 09:04 PM
