Anybody ever change over to angled valve stems like these, or other ones? The straight stems are such a PITA to get to for checking or airing up. If you've got better ones, post 'em up.
I used these on the original wheels that came with my Ultra. Well made and worked like a charm. Don't need them on my new wheels but I recommend them highly.
The shop that did my tire changes put some shorter valve stems than original. Makes it much easier to do pressure checks now. And still looks original.
I had one for my rear for about 2 years. Somehow it gotten loose and start losing air, I could spin the stem with my fingers. The jam nut inside must had worked loose.
I had Dynabead in the tire, wondered if that has anything to do with it. Or should I use blue loctite on the jam nut?
Yep, that is a mod worth doing, but you can get them cheaper than that.
