Installed heim type joints....problem
Old Mar 19, 2016 | 04:12 PM
roundy's Avatar
roundy
Default Installed heim type joints....problem
So I found a thread on here with the parts to do the above switch and located some joints in the UK.
Put it all together and took her out today and really struggled to get into 1St gear, had to keep shifting up and back and really forceful to go into 1St?? Popped the original linkage back on, balance returned to the force?!
Any ideas?? I am baffled...
Old Mar 19, 2016 | 04:21 PM
QC's Avatar
QC
Did you match the center to center lengths from the old set-up to the new?
Old Mar 19, 2016 | 04:24 PM
Punjabi Rider's Avatar
Punjabi Rider
Make sure heim joints are free to move around after installation and also measure the length should be about same as the stock shifting rod. If joints are binding against both transmission rod and the primary rod then you need to use some washers to have free play on both ends and both side. You should be able to wiggle it with your fingers freely.
Old Mar 19, 2016 | 04:43 PM
GTK's Avatar
GTK
Probably need to shim out transmission end with washers to stop bind.
Old Mar 19, 2016 | 05:12 PM
batman.'s Avatar
batman.
I have the opposite problem. Mine wiggle so much they rattle at idle. I can grab the bar and there quite.
Batman
Old Mar 19, 2016 | 05:17 PM
QC's Avatar
QC
Batman
Buy some better Heim joints. They are not created equal.
Old Mar 19, 2016 | 06:14 PM
Loc_Tite's Avatar
Loc_Tite
Sounds like you may have too much distance between the mounting holes maybe?
Old Mar 19, 2016 | 06:24 PM
Boomer1143's Avatar
Boomer1143
Batman
Batman, put a small o-ring on the back side of the joint. That's what I did and it keeps the linkage from moving and no more rattle.
Boomer
Old Mar 19, 2016 | 07:16 PM
hardheaded's Avatar
hardheaded
all heim joints are not created equal, buy some good ones and get them space out correctly and all will be good.
Old Mar 19, 2016 | 07:36 PM
xcbullet's Avatar
xcbullet
That's my new rattle, I was checking my bell today can't even here it. I hear going slow down the road. Just installed cheap eBay one someone mentioned on here. I like it, alot better firm shift. Something is not right with OP setup as it should be better. I have one thick washer behind the trans heim link. Tried to make sure shifters where in same height as before.
