Immobiliser Security System
Old Mar 19, 2016 | 05:44 PM
J-FRAME's Avatar
J-FRAME
Default Immobiliser Security System
In 2000 when I bought my Electraglide new I had the dealer put a security system on my then new bike. I used it some in the beginning then put the remotes away as it became a pain in the neck. It was always going off. False alarm etc. Big waste of what I remember as $500. Anyway years later now I found the remote and charger etc and wonder if I should take all the stuff off the bike and throw it away. Problem is I really don't know what to take off as I have no drawing etc to go by on what to remove. Does anybody remember these alarms and what I need to remove? Any help? Thanks
Old Mar 19, 2016 | 06:07 PM
J-FRAME's Avatar
J-FRAME
I just pulled the seat off and I find no connections at the battery that I can disconnect or follow to find the unit /units to remove
Old Mar 20, 2016 | 07:52 AM
nhrider1's Avatar
nhrider1
I had one on my 2000 Road King. It eventually failed and caused the bike to die on the road....so I recommend you remove it before you have a similar problem.
Look around under the seat or side covers for the module. When you find it remove it and all the wiring harnesses attached. There was a lot of wiring and it interconnects with the stock harness(s). It was however plug and play and contained all the mating connectors, so it was easy to remove and there were no splices.
ramhunter9
Electrical/Lighting/Alarm
Apr 18, 2015 06:50 AM
JefFLH
Jan 24, 2011 12:28 PM
jbird79
Nov 24, 2009 08:11 PM
cnielsen4130
Apr 3, 2007 10:19 PM
subculture08
Jul 18, 2006 01:14 AM
