Voltage Reg. Spikes w/ pics
Thanks to you and HDForums, I never could afford to keep our 2 HD's running otherwise
That is one ugly connector. On the female, stator side I have to wonder what the wire looks like inside the connector that melted, is the wire corroded too? Does the spade fit in the female connector tight? Try fitting a spade on that end and see if it pushes into the connector or is tight. If your stator tests good maybe you could find a connector from a bad one and splice it in. and use dielectric grease in the connector to keep moisture out.
Check your alternator while you are looking at the connector, here's generic instructions I had:
Stator testing
Turn the bike off and disconnect the Stator from the Voltage Regulator.
Testing a 3 phase Stator, (A single phase stator is tested in the same manner but the plug will only have 2 sockets).
The end of the connector from the stator has 3 sockets. Set your meter to ohms and connect one lead to the battery negative. With the other lead make contact with the conductors inside each socket. You are checking for a grounded coil winding, each socket should show an open circuit to ground, no continuity.
Now take both meter leads and check resistance between each of the three sockets, 1-2, 2-3 and 1-3. The resistance should be 0.1 – 0.3 ohm.
Next check the Stator’s AC output. Set the meter to ACV 100V scale. With the Stator unplugged from the VR and the bike in neutral, start the bike. Run the bike at 2,000 rpm and check the Stator output between sockets 1-2, 2-3 and 1-3. The voltage should read approximately 32-46 Volts AC, for the 50 amp Stator. Stators with other Amp ratings will be similar.
If the Stator continuity tests to ground and Phase to Phase are good but the output is not the Rotor may be bad.
One other indication that the stator may be bad is if your primary oil smells like a burnt circuit board.
The Voltage regulator should not allow over 15V. Check to make sure the mounting points of the reg are clean and that the positive and negative lead from the reg to the battery and ground are tight and clean and the wires are good, ohm them out and wiggle to see if the resistance changes, it should be very low.
Good Luck
Bill
You'll need to replace the connector and more than likely the VR at minimum.
The last connector I changed out was like 5-10 bucks from HD but the VR can be expensive although there are plenty of aftermarket versions for less that work fine. Cycle Electric or the J&P version works well.
If your stator is not shorted or open you'll usually be ok - at least for awhile.
Heat and vibration is the main killer of stators and their life can be drastically lessened when forced to operate so hot the output wires are melting the connector...
The 16V spikes dropping back to 14V indicates the voltage regulator is probably bad. Run the tests Vernal mentioned and replace the bad component(s). It's most likely the voltage regulator, but the stator needs to be checked too.
Bad News VR is toast and is going to be a PIA as I have the HD oil cooler installed and the lines run over the top of the mounting bolts @#$$%
I hate running the line along the frame PIA again
Did the voltage drop test to the grounds and they all read the same.
Thanks again Folks, checking on VR's from Cycle Electric to comapre to HD.
HD 74505-02 197.32
Drag Specialty 179.95
JP Cycle- Cycle Electric 187.99
ebay
http://www.ebay.com/itm/Harley-David...FUrp2S&vxp=mtr
Says it replaces the OEM 74505-02 Transpo for 136.79
http://www.ebay.com/itm/HARLEY-DAVID...tS0iBl&vxp=mtr
says mfg by Transpo H0502 for 125.00
is Transpo the OEM mfg for HD?
This if the motor side of my stator that was shorted out when my clutch basket bearing began crumbling and sending bits of metal through my primary. The metal collected on the one arm of the stator, penetrating the wire coating and grounding it out against the motor wall.
