exhaust gasket
Old Apr 2, 2016 | 07:10 PM
Tomspo04's Avatar
Tomspo04
I've installed quite a few sets. I always take off the leading corner of the gasket with some light sand paper before I start the gasket in the port. That allows the gasket to get a start before ot tightens up as you push it in with your thumbs. Hope that makes sense.
Old Apr 2, 2016 | 07:26 PM
jlasoftail's Avatar
jlasoftail
After I asked the question, I went back out to the garage and had them both in within a matter of minutes. I think the biggest thing was just to walk away from it for a few minutes and get my blood pressure back down, lol. I've put in other styles with no trouble at all, but this was my first time using OEM ones. A little oil helped for sure, other then that it was just a matter of pushing with my thumbs all the way around. Some of the other tips could work great if you have the room, but with the lower fairing in the way, things were pretty tight.
Old Apr 3, 2016 | 01:39 AM
Tomspo04's Avatar
Tomspo04
Glad it worked out for you. You're absolutely right about just needing to walk away from the project sometimes. ��
Old Apr 3, 2016 | 12:02 PM
skydude426's Avatar
skydude426
Originally Posted by msocko3
I just get it started square and then start working my way around it pushing with my thumb, it's not that difficult.
That's what I do also.
Old Apr 3, 2016 | 12:15 PM
Custardglide's Avatar
Custardglide
Did the same thing on Friday installing my new dresser duals on my "new to me 02 FLHRSE". Wish I had thought of the PVC pipe trick tho!!!
Ady
Old Jul 3, 2021 | 01:06 PM
Chemdog70's Avatar
Chemdog70
Stage I
Default Double copper rings
Had a similar issue on a buddies bike. One copper Ring and still leaked a little so an older motor head said place 2 of those rings in each port. Amazing that worked and he has not had any issues since.
plus they go in really easy if u freeze them for a few hours.
Old Jul 3, 2021 | 07:21 PM
Taxgod4u's Avatar
Taxgod4u
A large socket will work if you dont have any PVC
Old Jul 3, 2021 | 07:22 PM
roussfam's Avatar
roussfam
That's what I use ^^^^
Old Jul 4, 2021 | 12:03 PM
Joe from So Cal's Avatar
Joe from So Cal
I just did my 2016 RG. Cleaned the surface of the port, fitted it in by hand. Piece of cake.
mndelrosario
Sep 23, 2016 01:31 PM
je3169
Jun 9, 2015 12:44 PM
clayharley
Oct 23, 2013 07:06 AM
Rickr01
May 7, 2011 08:20 PM
1HD2NV
Mar 19, 2010 03:40 PM
