Stage 1
Old Apr 5, 2016 | 02:41 PM
decencyxdefied's Avatar
decencyxdefied
Certified stage .5
Old Apr 5, 2016 | 03:07 PM
jt metal's Avatar
jt metal
If your filter is due for replacement, why not go with a k&n. Is it going to breathe that much more to warrant a tune, no.
If you have to have a certain intake cause it looks good, that's different.
I'd put a k&n in, then when the money was right, get a tuner.
Ride on.
Old Apr 5, 2016 | 03:17 PM
shekmark's Avatar
shekmark
DK Customs shows a Dyno chart comparing a stock late model filter to a aftermarket model. The difference was substantial. Also the idea of eliminating sucking hot air/oil into your intake.
Old Apr 5, 2016 | 04:11 PM
RKZen's Avatar
RKZen
I could be wrong, but DK may have had other things done for the difference, including a proper tune and baffle change. The OP might as well do a full Stage 1.
Old Apr 5, 2016 | 04:44 PM
Truble's Avatar
Truble
Originally Posted by CHIEF MIKE
My main concern is whether or not the K&N filter replacement would flow that much more air than the stocker.
Just changing the filter and slip ons is not a stage one, I see no need in spending money on remapping for that but I would go with the K&N filter it definitely breathes better than a stock air filter. Imo
Old Apr 5, 2016 | 05:12 PM
lp's Avatar
lp
I've run the K&N (for 2014 with stock air box) with slipons for over 10K without any issues. I then put a PV on the bike to see what it was doing. Not much.
Later played around with the "Improved Stock tune" and it actually ran a little better. Since then I'm back to stock pipes and the K&N with the stock tune. All fine.
Old Apr 5, 2016 | 07:57 PM
Nick1's Avatar
Nick1
Just get the full stage 1 tune. The sound and improved HP will be worth it in the the end.
Old Apr 5, 2016 | 09:59 PM
wscott's Avatar
wscott
Originally Posted by rick
FWIW. I recently went to a new intake and when we removed the stock filter that thing was dirty as hell.Bike has 2k miles don't know if that's the reason or not.
Thats because crankcase is venting blowby gases full of hot oil mist thru air filter,go to DKCustom's external vent system and that wiil not be a problem anymore.
My bikes air filter used to get oily & dirty enough after only 3,500-4k miles to require cleaning.
But after i installed DK's external breather kit for crankcase the air filter doesnt look as dirty at 6,500-7k miles as it used to 3,500-4k miles.
Scott
Old Apr 6, 2016 | 08:02 AM
msocko3's Avatar
msocko3
Don't believe everything you see, that chart and write up is what Judge Judy would call "Puffery". Fuelmoto did the same test with their Pro Billet air cleaner and didn't get those type of results. The FM dyno showed a 1.78& HP and 3.2% torque increase. In keeping with the rules on this site of not mentioning competing sites. There is a site where a lot of the industry leaders hang out to answer questions and compare notes, several of them have even stated on Stage 1 and mild Stage 2, the Rushmore air cleaner is all that is needed.
Keep in mind when you compare dyno charts, those numbers can be manipulated to show a better light on a product. They are also numbers gained at Wide Open Throttle. How many folks realistically spool their engines up to 5,800 - 6,200 rpm on a regular basis? Not many, so in the range most ride, the gain is nothing. You will gain more from a good exhaust and a tune, than you will with an air cleaner. The only reason to change an air cleaner on a Rushmore bike, or trike, is because you want to change the looks or you're doing ported heads, a bump in compression and cams to match that combination.
Now venting the heads to atmosphere vs into the intake, that's a whole different kettle of fish. External venting may give you a smidgen more power or torque, not sure if anyone reputable has measured it or not. The biggest gain is you do not suck all that **** into your engine and build carbon.
Old Apr 6, 2016 | 08:33 AM
OldPhat's Avatar
OldPhat
If you ever plan on getting rid of your Catalytic Converter then I would get a Power Vision tuner.
If you keep your Bike the way it is, Full Bore and a K&N filter, go with FL-ViED-10 from NightRider
