Compensator removal/install tool questions
Old Apr 6, 2016 | 07:15 AM
Eunoterpsia's Avatar
Eunoterpsia
Surprise that no one has mentioned this to the guy...
Rarely... will you be at the point where you "might as well" go the rest of the way and remove the inner primary and replace the primary bearing and race.
Old Apr 6, 2016 | 07:44 AM
GriffinDenim13FLHX's Avatar
GriffinDenim13FLHX
Maybe this video can help you out a little as well. Good luck on your project.
Old Apr 6, 2016 | 07:59 AM
markwolula's Avatar
markwolula
I hear ya Eunoterpsia,,
But he was asking about comp replacement specific tools..
I suppose , (for me), it would come down to, if the 2009 bike has high mileage or not..
If it had high mileage , and some tell tales signs of oil leaks, it would be a no brainer to go deeper and remove the inner primary ... Hell, if your going this deep , and the bike is a keeper , why not think about a new belt .. More specialty tools, and may just get out of his comfort zone ...
Cdal1's Avatar
Cdal1
Question, I took primary cover off to bring to Harley to glue the oil deflector on (they were out of adhesive and he said he would do it for me). The compensator nut on mine looks like it fit a 13/16" socket, I have read most used 1 1/2". Is this something that changed?
Old Apr 6, 2016 | 08:20 AM
voodoodrug's Avatar
voodoodrug
as mentioned. great time to go deeper. (09) upgrade the the stater(hi output charging system),new prim belt,maybe-->upgrade the clutch hub& w/precision hub bearing& inspect clutch,race,ipb,attitude tensioner. check alignment.heat bolt for removal and also chase bolt(tap dye) can of cleaner and air supply.
Old Apr 6, 2016 | 08:28 AM
LQQK_OUT's Avatar
LQQK_OUT
Yes, it has changed. On my 2011 Ultra which I just changed the compensator on, the original bolt needed a 13/16" socket.
1-1/2" for '99-'06, (except 2006 Dyna's), 13/16" for 2006 Dyna's and 2007-2013 all
T70 for Screamin Eagle compensator and models 2014+
Old Apr 6, 2016 | 08:53 AM
Cdal1's Avatar
Cdal1
Is the clutch nut still 1 3/16" socket
Old Apr 6, 2016 | 09:10 AM
LQQK_OUT's Avatar
LQQK_OUT
Originally Posted by Notgrownup
I bought a 8 hard plastic step locking block to lock the primary chain, it was $8.
I've read a few posts where people recommend against using a primary wedge type locking tool. The claim is that it puts a tremendous amount of side load on the crank and transmission shafts. The locking bar is a better tool for this. The bending forces at the shaft are more than 10 times higher using the wedge.
http://harleytechtalk.org/htt/index....html#msg575358
Old Apr 6, 2016 | 01:33 PM
09TxRoadKing's Avatar
09TxRoadKing
Just had mine apart this past weekend and I have the 09 Road King and can tell you the compensator bolt is a 13/16 and the clutch is the 1 3/16"
Old Apr 6, 2016 | 04:49 PM
Cdal1's Avatar
Cdal1
Just finished installing the se comp.
I tie wrapped the chain adjuster and after installing everything the chain has more slack than before. When I start it will it auto adjust the chain where it needs to be?
