Compensator removal/install tool questions
Old Apr 5, 2016 | 09:31 PM
Cdal1's Avatar
Cdal1
Default Compensator removal/install tool questions
Hey everyone, I'm about to install a new compensator and want to be prepared with all correct tools and sockets.
I looked through manual and didn't see mention of actual nut sizes. So can anyone tell me what size sockets and tools I'll need to remove original comp and install the se comp.
This swap is on a 09 road King classic. Thanks
Old Apr 5, 2016 | 09:55 PM
HFS's Avatar
HFS
I wanna say it was an 1-1/2" nut...
But I had to borrow it out of the tool crib. Maybe that was on the Baker one I installed. [If memory serves].
I used a rag and jammed it into the chain to hold the primary. It worked, someone suggested it here. I'd get the HD tool if I did it again though.
Make sure you have a looooong drive bar and rent/borrow a long torque wrench.
Use red thread locker on the bolt too.
Have fun...
Old Apr 5, 2016 | 10:38 PM
BJB's Avatar
BJB
Have a scrap piece of hardwood or 2" X 3/16" X 8 inches or so to cut to the proper length to make a primary drive locking tool. Your bearings will appreciate it.
A T70 socket is required for the new bolt. You can get them for less the $10. A long torque wrench to tighten and a breaker bar and likely a pipe extension to break it (nut) loose. The torque wrench will appreciate not being used as a breaker.
Old Apr 5, 2016 | 10:47 PM
Cdal1's Avatar
Cdal1
Ok here's a list of what I think I need, tell me if I'm wrong on anything or need to add to it.
1: 1 1/2" socket for comp bolt
2: t70 torx for se comp bolt
3: 1 3/16" socket for clutch nut
4: Primary locking tool
5: breaker bar
6: torque wrench
7: red loctite
Anything else?
Old Apr 6, 2016 | 05:07 AM
Cdal1's Avatar
Cdal1
Another question as I'm about to tear into it.
Do I need to put bike in gear during the installation?
Old Apr 6, 2016 | 05:30 AM
Pine Tree's Avatar
Pine Tree
MODERATOR
Shouldn't be necessary if you're using a piece of flat stock as your primary locking tool.
Just two thoughts of advice...(1) don't use the rag method as a locking tool...the nut on the comp can have more then 185 lbs of torque applied and putting that much pressure on the chain might cause some damage noticeable only later...(2) removing/reinstalling both the comp and clutch pak as one unit usually makes the process a whole lot easier.
Hope that helps.
Old Apr 6, 2016 | 05:46 AM
lp's Avatar
lp
You need a torque wrench that goes to 175 foot pounds.
Old Apr 6, 2016 | 06:16 AM
markwolula's Avatar
markwolula
As mentioned above,, a torque wrench that goes to 175 f/p,, that usually messes up a few... I'm pretty sure all the tools required have been mentioned to replace comp..
Other than the tools required to remove primary cover and floor boards etc, which I take it, you already have ...
One thing I will mention, that is not regarding tools etc, is ,, before you install the t70 torx bolt, which comes with the SE comp, make sure you clean the inside threads , (that the bolt goes into), of old loctite etc . Spray brake cleaner, (or similar), in there, and blow out with compressed air... Also spray brake cleaner on the the new bolt and run it in and out a few times, and finish off with a good blow of compressed air.. Good luck with the install ...
Old Apr 6, 2016 | 06:37 AM
jmaniace's Avatar
jmaniace
5: breaker bar
6: torque wrench
7: red loctite
Anything else?
Add a MAPP torch to this list. You will need to heat the bolt up before you break it loose.
Old Apr 6, 2016 | 06:48 AM
Notgrownup's Avatar
Notgrownup
I bought a 8 hard plastic step locking block to lock the primary chain, it was $8.
