Uggh, regulator bad
Old Apr 9, 2016 | 09:56 AM
UltraClassicWNY's Avatar
UltraClassicWNY
Default Uggh, regulator bad
What do you guys recommend for a regulator? I'm up around 15.6 V on my digital mutimeter. Stay stock or any recommendations?
Old Apr 9, 2016 | 09:59 AM
TriGeezer's Avatar
TriGeezer
High voltage is not the usual failure mode. But, 15.6 is too high.
Anyhow, I went stock HD when mine failed. The new one has lasted 2 years so far. Knock on wood.
Old Apr 9, 2016 | 10:18 AM
mkguitar's Avatar
mkguitar
yes, anything over 14.8 is bad.
you are sure your meter is good?- a fresh duracell 9 volt battery will be about 9.8 out of the package.
I've used HD regulators over the years - 1 on my 88 in 1990 1 on my 1995 in 2010.
and all good.
Mike
Old Apr 9, 2016 | 11:21 AM
voodoodrug's Avatar
voodoodrug
cycle electronics
Old Apr 9, 2016 | 11:43 AM
wscott's Avatar
wscott
Couple other things to keep in mind are if the battery is getting tired & or isnt that old but is developing a bad cell the volt reg will sense it needs more charging then normal which some rare cases can lead to " higher then normal " charge voltage readings.
Also,sometimes a bad dirty corroded ground/connection at battery & or also on either of the 2 grnds (1 to frame & 1 under starter attached to trans case) can cause higher then normal charge volt readings too.
scott
Old Apr 9, 2016 | 11:55 AM
zeke383's Avatar
zeke383
Where did you check the voltage?
Old Apr 9, 2016 | 12:30 PM
FlamedFXR's Avatar
FlamedFXR
I used HD. 177 from Boardtracker.
Old Apr 9, 2016 | 12:45 PM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
If one rectifier went (out of the 6) you should see AC ripple on your digital multimeter.
Old Apr 9, 2016 | 02:47 PM
UltraClassicWNY
I checked the voltage right at the battery tender plug. How would I check for a voltage assuming it was a diose?
Old Apr 9, 2016 | 03:28 PM
Expat1's Avatar
Expat1
Set your multimeter to Vac, you should not have more than 0.1-0.2 Vac using the tender plug. The maxi fuse dampens the ac signal by sending the poorly rectified voltage to the battery. Be sure to tighten all connections before taking a decision.
