Torquing rocker covers
Old Apr 10, 2016 | 04:02 PM
SavageChopper's Avatar
SavageChopper
Default Torquing rocker covers
I'm sure someone has thought of this, but figured I would pass it along.
I torqued my rocker covers "by feel" when I built my 107. This afternoon I noticed a small oil leak out of the rear rocker box so I tightened it down a little more and considered buying an adapter from Motion Pro. I found that I was able to put my 3/8 torque wrench on the end of the 7/16 box wrench at a 90 degree angle and tighten every bolt with the tank still on. I was off by at least a half turn going by feel.
Hope this helps somebody.
Old Apr 10, 2016 | 07:04 PM
qtrracer's Avatar
qtrracer
What wrench were you using for the initial tightening?
Old Apr 10, 2016 | 07:15 PM
jlasoftail's Avatar
jlasoftail
Would the length you are adding to the wrench not change the accuracy of the torque wrench? I would think this would add mechanical advantage... I might be way off on that, but that's how I would picture it.
Old Apr 10, 2016 | 07:22 PM
threedeuce5's Avatar
threedeuce5
Unless the adapter or extension is perpendicular to the torque wrench you're going to be way off on your torque values IIRC.
This is a good way to over torque or snap off bolts in unfortunate places IMO.
Old Apr 10, 2016 | 08:04 PM
SavageChopper
As stated in my original post, I have the torque wrench 90 degrees to the box end wrench. When you do this, the torque value is correct.
Here are instructions to MotionPro's adapter that may clarify: http://www.motionpro.com/motorcycle/articles/view/2794/adjustable_torque_wrench_adapter__08-0380/
Old Apr 10, 2016 | 08:24 PM
qtrracer's Avatar
qtrracer
You used your "adapter" correctly. That was never an issue in my mind. I am still curious as to what tool you used to get the values so far off by feel.
Old Apr 10, 2016 | 08:25 PM
jlasoftail's Avatar
jlasoftail
Good to know. I'll have to keep that trick in mind.
Old Apr 10, 2016 | 09:13 PM
SavageChopper
Got ya. I had originally torqued a bolt using a torque wrench then tightened it a bit more with a box end wrench to get a feel for how tight to go. I realize I should have done it correctly to begin with.
buddy67
Engine Mechanical Topics
Mar 11, 2019 11:38 AM
lloydrtr
Nov 1, 2011 08:13 AM
MoChrome
Aug 29, 2010 11:21 AM
Ragnar Danneskjöld
Aug 27, 2010 12:25 PM
99FXSTC
EVO
May 23, 2008 03:49 PM
