My first service on my EG one of the twist locks had worked loose by the time I got home. I strung a small bungee cord between the two hook rings, then ultimately went to 5/16" hardware with nylock nuts. No worries now for theives or bags falling off, but it's a small hassle to drop the bags now.
I got this idea from another post. 5/16" clevis pin cut to length with the end rounded off with a grinder, and fender washers on the wheel side and inside the saddlebag. No tools, can't loosen, hard to tamper with. I only use this on the front, and have the OEM fasteners on the back.
Wonderful way to go. If I hadn't put in stick-on bag liners that made my connectors very tight, I would recommend this method. Is it me or is the OEM spring tension not enough?
I heard a lot of stories about those stock pins when first bought my bike. They rattle loose or how easy it is for a thieve to snip that wire and be gone in the blink of an eye. I went to my local hardware and the guy that helped me had bags stolen before. He showed me what he uses now and only costed me $5.00. So far so good.
I received a recall notice from my deanship here on the Sunny Coast, I drop my CVO Street Glide off to have my clips and pins upgraded, I picked my bike up and on the way home I wondered why everyone was tooting there horn at me.
I finally looked back and my left bag was hanging off only to be held in place by the connecting wiring which holds my speakers and amp in place.
I have the stick on bag liners and use this set up without any issues. Just make the clevis pins a little longer.......
