hogtunes
Old May 16, 2007 | 02:01 PM
STOUT's Avatar
STOUT
Default hogtunes
Can anyone tell me if 98-05 Hogtunes speakers will fit in 07 street glide. The woman at Hogtunes was not to sure she said something about different ohms. Harley changed from4 ohms on 98-05to 2 ohms on 06-07 so they may not sound as good?????
Old May 16, 2007 | 02:05 PM
kdietz's Avatar
kdietz
Default RE: hogtunes
sorry....nope....for the reasons you stated
Old May 16, 2007 | 02:30 PM
FULLDRAWMIKE's Avatar
FULLDRAWMIKE
6th Gear
the oem speakers in my 03 RG state 8 ohms on them and the hogtunes are 5.75 per the manual. What years had 4 ohms? Or does HD just use whatever they can get cheap.
Old May 16, 2007 | 02:33 PM
the_icemAN's Avatar
the_icemAN
'07 radio system uses 2ohm speakers (correct me if I'm wrong .... seems I've read this about 100x in the different speaker threads). I would think you would want, optimally, to get speakers running 2ohms... but I'm no audio "expert"
Old May 16, 2007 | 02:51 PM
iclick's Avatar
iclick
ORIGINAL: STOUT
The '06 and '07 speakers are 2-ohm, as you've stated, but traditionally amps are multi-rated for different impedance, within limits. Lower ohm rating means less impedence (resistance) and will output more power. If the amp can take 4-ohm speakers, which I'm fairly sure it can, your output will be lower--and since the amp is marginal anyway I wouldn't do it.
Old May 16, 2007 | 03:39 PM
STOUT's Avatar
STOUT
Thanks iclick
Harley_RN
Apr 7, 2010 05:33 PM
jandb125
May 30, 2008 02:59 PM
thall
Apr 3, 2008 08:33 PM
DeathWind
Jul 16, 2006 10:24 PM
LittleSkull
Aug 27, 2005 04:01 AM
