Tire Failure
Old Apr 28, 2016 | 12:50 PM
bagman1's Avatar
bagman1
I would wonder if its just from the different compounds they use now. There's a hard compound in the center chicken strip and a softer one on the sides, maybe that's inherent of the design. I think I saw that on mine or on a past Mettzler. Id have to look again.
Frankly, I would write or contact Dunlop, they have tire engineers that can address your concern. Dealers will just give you some BS opinion of what they think they know.
Old Apr 28, 2016 | 01:56 PM
xcbullet's Avatar
xcbullet
Something not right the bike should be able to bottom out with out touching stuff.
Old Apr 28, 2016 | 02:11 PM
grbrown's Avatar
grbrown
Wink
I agree, so let's stand back a bit.
Doesn't matter how much you both weigh, if you have stock factory shocks then nothing should touch anything when your shocks are at full compression. You've done well to identify that those clips are the cause of those marks. I suggest you challenge the dealer to rectify what looks like a fault with your bike, so your tyre doesn't touch anything.
Especially if you have a high combined weight, then there are shocks out there that can significantly improve your ride. Call HDF sponsor Howard at Motorcycle Metal, he can custom build you a set of suitable Ohlins shocks, with the correct springs etc for your weight. It's the only way to travel!
Old Apr 28, 2016 | 02:19 PM
Jrsess's Avatar
Jrsess
Probably a good idea to check your tires often. I try too when ever cleaning or servicing the bike. JR
Old Apr 28, 2016 | 02:56 PM
GTK's Avatar
GTK
100 lbs over gross acceptable weight,and thats probably on the low side, & wondering why bike bottoms out. Your lucky Moco bought you a tire. Biguns like you and wife need to upgrade front and rear suspension before you run into other problems.
Old Apr 29, 2016 | 02:56 PM
Ibfuelish's Avatar
Ibfuelish
True story there. If the new tire hadn't already been mounted on my rim when I made my final judgement, I would've said no thank you. But, it all happened pretty fast.
I knew why we were bottoming out. Just didn't think Harley would allow the inner fender to be the suspension travel limiter. Should be stopping before it touches fender. The fender doesn't show any indication that its touching and neither do the two clips.
So either, the two compounds are separating or the clips are touching ever so slightly.
Either way, clips gonna get filed down and putting progressive 416 air shocks on. I ride at too varied of weights to use a standard spring gas filled. So, we'll try these 416's. Research shows they handle 75 psi, which should give me what I need. Next thing is to load up and go to a weigh station and see what each tire is carrying. That way I know if I'm close to blowing a tire just from my fat ***.
FATKEVIN
Oct 2, 2015 11:31 PM
ironhide_uk
Jan 26, 2011 03:52 PM
RoadKingRobb
Jun 9, 2010 01:37 PM
07BLKBOB
Jan 17, 2008 01:08 AM
jca_54
Jan 28, 2007 06:29 PM
