Hands going numb
Old Apr 28, 2016 | 06:37 PM
JB WILD's Avatar
JB WILD
Stage IV
Is it vibration problem or a circulation problem. Putting your arms up it might just be your hands are going numb because of them being over the height of your heart. If you put your hand down by your side and the blood returns to them you'll have your answer.
Old Apr 28, 2016 | 06:46 PM
Duracell's Avatar
Duracell
The thumb, pointer, and middle finger share a common nerve bundle. Carpal tunnel issues at the risk could be the reason but a more likely culprit is the height of the bars. All Harley handle bars vibrate but it may be the height change is affecting your neck and shoulder position and pinching that nerve bundle where it exits your cervical area.
Ask me how I know
Ron750's Avatar
Ron750
Do you wear gloves? I use gel pad gloves, otherwise I get carpel tunnel.
Old Apr 28, 2016 | 07:07 PM
ZenGlide's Avatar
ZenGlide
I had a similar issue after installing 12" bars on mine. Someone here suggested that I might have my new bars pushed too far forward and I was riding with my arms almost straight out. I rolled the bars back a couple of inches so my arms are more relaxed with a slight bend in my elbows. This more relaxed position also allowed me to relax my grip on the bars. I haven't had the numbness problem since.
Old Apr 28, 2016 | 07:25 PM
BLKPRLFLHTCU's Avatar
BLKPRLFLHTCU
How are your shoulders, like ZenGlide said make sure your elbows are bent it reduces pressure on you shoulders back and neck.
Old Apr 28, 2016 | 07:49 PM
tnriverluver's Avatar
tnriverluver
Try loosening your grip! Anytime I find my hands going numb regardless what bike I am on I just open my hands for a while using my palms only to hold onto the bars for a few miles and then I'm good again. A throttle rocker/throttle boss on the throttle grip helps greatly with doing this
Old Apr 29, 2016 | 08:40 AM
Paul-Pacman's Avatar
Paul-Pacman
Thinking how I ride, I remembered my arms are extended straight out with locked elbows. Started on the bars last night and finished early this morning loosening the bars and dropped about 3" and repositioned the controls. Got everything put back together and went for a ride. Wow! What do you know. It feels great. Thanks to everyone for all the help. No thanks to the people at Harley.
Old Apr 29, 2016 | 09:38 AM
Sierra977's Avatar
Sierra977
Secondary Raynaud's Syndrome (ie Vibration Syndrome)
http://www.cdc.gov/niosh/docs/83-110/
Bothered me for decades. Nothing you can take for it (went to doc and tried a couple medications - nothing worked). Best advice I can offer is to loosen your hold on the handgrips and try not to PUSH the grips while riding - lightly PULL grips with fingers not palms. For me the numbness exacerbates when I push the bars with the web of my thumb - I consciously try NOT to do that. It seems there is a nerve pathway there that effects thumb, index and middle fingers. Pressure and vibration there somehow acts to shut down blood circulation to those areas.
ETA different bars may change your grip angle and make problem go away. Drag bars work best for me but my motor is a SGS so...
Old Apr 29, 2016 | 09:50 AM
Lowcountry Joe's Avatar
Lowcountry Joe
Handlebar position is an individual thing. Apes or shorts, the position has to be correct for the individual or there will be issues. Glad you were able to adjust it to suit you.
Old Apr 29, 2016 | 11:41 AM
LiiT's Avatar
LiiT
Loosen that death grip. I had the same problems on my FXDS until I got one of these..
