Hands going numb
Old Apr 28, 2016 | 04:02 PM
Paul-Pacman's Avatar
Paul-Pacman
Default Hands going numb
I just had 10" mini apes installed on my 2015 Ultra Classic. I was advised by Harley I should remove the rubber handlebar riser bushings and replace them with the polyurethane riser bushings to prevent handlebar flexing. Made good sense to me so I had it done. I noticed an immediate difference. I get about a half hour into my ride and I want to cut my hands off. The vibration makes my hands numb. I went back to Harley and they said this was the first time they heard of that. They took my bike in the back to give it a once over and advised me everything look good. Has anyone else have this problem. My bike has only 5200 miles on it and I want to drive it off a cliff. I did not have this problem until the bars were changed.
Old Apr 28, 2016 | 04:13 PM
Ultraboy105's Avatar
Ultraboy105
Whole hand goes numb? Certain fingers, Arms, Shoulders or wrist? How tall are you? How much do your mirrors vibrate?
I haven't experienced that since I rode a 1998 Heritage.
Old Apr 28, 2016 | 04:23 PM
Paul-Pacman
Thumb, Pointer and Middle finger. Hands only. 5-10 tall. I have the Harley windshield trim mounted mirrors that vibrates about the same as before the bar change. After thinking about it, Harley has rigid mounted motors and went to rubber mounted motors to cut down on vibration transmitted through the frame. Makes me think same goes for the bars.
Old Apr 28, 2016 | 05:34 PM
OldMike's Avatar
OldMike
The Harley poly bushings are not too much different from the stock bushings but are supposed to last longer. I just changed mine over the Winter with my new bars so I can say as far as vibration I don't notice any difference. The Harley website says they can actually reduce vibration. You may not be in sync with the vibe.
The bar position/height probably does not agree with you. Lots of people like the high bars but they are not for everybody. My hands get numb after a long time so I use the cruise and rest my hands by my side occasionally.
Old Apr 28, 2016 | 05:48 PM
INJEKTER's Avatar
INJEKTER
has the pull back changed? i changed to a more pull back bar , which makes me lean back more...leaning back more makes me hang on tighter, hanging on tighter makes my hand go to sleep...
Old Apr 28, 2016 | 05:50 PM
Punjabi Rider's Avatar
Punjabi Rider
My hands been going numb for few years can't stand to follow any one always use cruise control even in mild twisty roads. New bars must have change your wrest position from previous bars and you might want to go back to the same ones if those didn't cause any discomfort. Quite few things look awesome while the bike is parked but very uncomfortable on the long rides.
Old Apr 28, 2016 | 06:01 PM
str8shuutr45's Avatar
str8shuutr45
I had a similar problem with my King when I first bought it. I ended up changing out my bars to A Heritage style (upgrade my ride from Heritage to RK). Just wondering if you had a chance to try the mini- apes you installed before you actually changed them over. The angles could be all wrong for your seat, height, arm, length, etc.
Have you considered pulling the bars closer to you to change the angle?
OldMike's Avatar
OldMike
This bar also changes the wrist angle, it's the one I installed to give me more pull back so I can rest against the seat back rest.
https://www.hdforums.com/forum/new-r...s-install.html
Old Apr 28, 2016 | 06:12 PM
mkguitar's Avatar
mkguitar
I have carpal tunnel
...and for that reason I use rubber bushings, they better dampen the vibrations- the tension can be altered to tune the vibrations in or out.
I tried poly bushings 25 years ago and tossed them on day 2- luckiy this is on teh fxr where everything is accessible.
taller bars have more leverage so you need a stiffer joint, that's why they suggest poly bushings- but there is the drawback.
you may be able to loosen or tighten the bolts and see if it gets better.
or even swap for another type or density of poly- these are easily turned on a lathe from skateboard wheels- which come in various grades
2.- any blood circulation problems?
mike
Old Apr 28, 2016 | 06:13 PM
Ultraboy105
This is a symptom of carpal tunnel. If you apply too much pressure or vibration to the bottom of the palm or the wrist, you will aggregate the nerve.
You may even have carpal tunnel syndrome and the bars just highlighted the issue.
