Screaming Eagle
Old May 16, 2016 | 12:15 AM
OldPhat's Avatar
OldPhat
Welcome to our Forum David.
On a 2014 FLHTCU or any newer Rushmore model it's not worth it to change to a
Screamin Eagle Stage-I air cleaner unless you like the looks of it. The stock AC is
only a $60.oo K&N replacement air filter away from flowing all the air a Stage-I is
able to use. (K&N part # HD-1614)
If you are just adding aftermarket Mufflers, but not taking the Catalytic Converter
out of the header pipe and adding a Stage-I AC then you should use a Fuel Enriching
Device of some type. At that point the minimum would be, FL-ViED-10 by Nightrider.
The more you spend on your Stage-I setup, the better the performance is not always
case, at the end of the day. Do your research to get the best bang for your bucks for
a Stage-I.
Old May 16, 2016 | 04:28 AM
Rustrtal's Avatar
Rustrtal
Originally Posted by 0ldhippie
Actually the '14up air cleaners are pretty good. There is no/little gain changing it for "stage 1". Your biggest gain will be a proper tune, not a dealer download.
...and a new exhaust system or you have a Stage .5
When header shopping, you have choices of 2-1, 2-2 or 2-1-2.
Best performance = 2-1
Best Sound = 2-2
Mix of both = 2-1-2
As far as the slip ons/baffles go, lots of choices there too. I recommend you have the bike Dyno tuned by reputable tuner. Talk with them about the choices and options in regards to sound and performance.
Old May 16, 2016 | 10:05 AM
GEORGEW's Avatar
GEORGEW
Where in Illinois do you live?
TheOrg
Oct 28, 2023 02:22 PM
pgarbac
General Topics/Tech Tips
Mar 1, 2017 11:40 AM
Bug-Biker
Jan 8, 2015 09:12 PM
Jeff's 1st Harley
Sep 17, 2012 06:34 PM
BUZZBEER
Exhaust System Topics
17
Jul 16, 2009 10:05 PM
