Intermitten B1005 code
Old May 17, 2016 | 09:24 AM
Pirish's Avatar
Pirish
Default Intermitten B1005 code
Hey guys so I'm stumped here.. recently I've been getting:
B1005 Fuel Level Sending Unit High/Open Instruments
I've gone though the service manuals diag procedure and everything is fine. I can't seem to reproduce the code tripping.. It happens sporadically.
Eg: today riding fuel gauge is reading just under half, turn corner and gauge drops to E and speedo gas light comes on... straighten out ride a bit then gauge reads again and speedo gas light stays on... then it goes out...
suggestions? is it possible the sending unit is going?
Old May 17, 2016 | 09:47 AM
Boomer1143's Avatar
Boomer1143
I would sure take a look at the sending unit. Sounds like it looses continuity when turning. I would remove the sending unit and check it out with an ohm meter. I would think you would be able to reproduce the open in the system once the unit is out of the fuel tank and in hand.
Old May 17, 2016 | 05:54 PM
Pirish's Avatar
Pirish
it's not doing it when turning it's more when I'm accelerating. the gauge will drop to E from 1/2 or less then the idiot light will go on and stay on tripping the code... Thanks... at least now I know where to focus my diags... any more tips would be appreciated.
Old May 18, 2016 | 10:33 PM
Pirish's Avatar
Pirish
So pulled the console and canopy out... got at the float arm and connected the ohm meter up.. findings
SC says Full 7-14 ohms------My reading 9.2
SC says Half 30-38----- Mine 20-25
SC says Empty 74-95 -----Mine 40-45
Safe to say my sending units done?
Old May 19, 2016 | 07:11 AM
14GuineaPig's Avatar
14GuineaPig
From the 2006 Electrical Diagnostic Manual .... hope this helps .... it gives OHMS readings
Old May 19, 2016 | 07:37 AM
Xpressway's Avatar
Xpressway
It's suspect for sure. If your getting the errors from 1/2 tank down, the resistance lessons creating an "open" circuit, where it should be more resistive
Old May 19, 2016 | 12:37 PM
Pirish's Avatar
Pirish
thanks 14Guineapig but I have the same manual I was posting the values to get an opinion...
Xpressway--- That's what I was thinking... so I took apart the sending unit, cleaned the contacts and bristles, re-soldered the wires and put a new retaining clip on the float arm removing the excess play it had... now it's working within the specified Ohms as per the SC.
I don't think this is permanent but it will do for now.. Dealer want 160CDN for a new one so I'm going to try to squeeze the life out of this one.. I'll post in a couple day if it's still working or not.
Thanks everyone for the help
Old May 19, 2016 | 01:53 PM
ORradtech's Avatar
ORradtech
Used to be, on variably potentiometers, the coil/board/resistor or whatever they used would develop dead spots. But that's not what yours sounds like to me. If the problem comes back after your cleaning/refresh then I'd be thinking a pinched/grounded/broken wire between the guage and the sender. Or maybe a loose/dirty harness connector.
Old May 19, 2016 | 06:12 PM
Pirish's Avatar
Pirish
those were the first things I checked as per the procedures in the SC.... cleaned all connections applied dielectric grease and made sure all connections are good...
Here's hoping...
Pirish
Electrical/Lighting/Alarm
May 10, 2016 02:10 PM
rbm33
Apr 23, 2014 06:46 AM
HYPR
Jul 19, 2013 08:45 AM
jm1211
Apr 13, 2011 10:14 PM
marvincbr
Mar 12, 2010 06:40 AM
