Do Vance &Hines true duals rub?
Old May 24, 2016 | 09:52 PM
surveybob's Avatar
surveybob
Default Do Vance &Hines true duals rub?
I was talking to the tech at the Harley shop a few weeks back about which exhaust system is working best for the 2016 Unlimited. He recommended RC concepts and that I should stay away from V&H as they rub on the transmission and break pedal. Does anyone have any input on this? I really like the sound and look of the V&H and the reputation. Thanks in advance for any help.
Old May 24, 2016 | 10:17 PM
jimmmya's Avatar
jimmmya
On my 2014 Street Glide no rubbing anywhere its my third different set of pipes and my Favorite !!
Old May 24, 2016 | 10:20 PM
RollaMo's Avatar
RollaMo
Only when they are not installed correctly.
Old May 24, 2016 | 10:25 PM
Keithhu's Avatar
Keithhu
On my 13 FLTRU, they rubbed the brake pedal even with installing their spacer. I added floorboard spacers (nice to have anyway), and all good.
Not everyone reports this issue, I guess its manufacturing differences and/or slight installation differences?
Old May 24, 2016 | 10:34 PM
ricktherocket's Avatar
ricktherocket
No rubbing on mine.
Old May 25, 2016 | 08:50 AM
kishstl's Avatar
kishstl
My concern with mine wasn't the rub but the rob. Bad torque dip and loss of power. Sounded awesome though.
Old May 25, 2016 | 10:14 AM
Taggs's Avatar
Taggs
Installed myself V&H true duals on my 14 SGS with no issues at all. I have put on a few pipes over the years and found the VH to be one of the easiest when installed properly.
Not sure what your tech is talking about especially with brake pedal rub. The heat shield is cutaway in the area of the brake pedal lever to allow plenty of clearance there. Unless something has changed on the 2016 setup, I could be wrong.
Old May 25, 2016 | 11:42 AM
CaptainKirk's Avatar
CaptainKirk
I have the Dresser Duals and love them. Don't know if I lost any torque but they run MUCH cooler than stock headers and the OS 450's on the end of them produce an amazing sound. That said, tight now, I can barely get a piece of paper between the heat shields where the pipes meet on the right side. I'm a little concerned they will rub from vibration. I'm planning on loosening everything up and seeing if I can lower the front or raise the back pipe a little to give them a little more separation. Other than that, I can't say anything bad about them. The chrome heat shields are thick and finished flawlessly. Everything fit together perfectly and it was easy to balance the OS 450's.
Old May 25, 2016 | 01:28 PM
dyna rider's Avatar
dyna rider
Default V & H Power Duals
I have them on my 11 RGU and no rubbing at all, plus they gave me more low end torque than the stock pipes. The also sound much better and run cooler than stock.
Old May 25, 2016 | 03:53 PM
slowrollin's Avatar
slowrollin
No rubbing on mine
