Wheeldock center stand problems!!
Old May 27, 2016 | 07:33 PM
hover's Avatar
hover
Originally Posted by jberg
I like mine a lot. I use it mostly in the garage. Love to see the bike standing straight up. Doesn't stop me from using my J&S Jack.
Jberg, what shock pressure do you run, and can you tell the difference in operation at different pressures? I usually run about 30psi. Higher shock pressure should raise the frame up making it easier to move the bike off the stand?
Old Jun 3, 2016 | 01:53 PM
jrat69's Avatar
jrat69
jberg how do you still use your jack with the stand? Mine is 2012 Road King, the jack slides under the bike nice when on the center stand, but with the jack all the way against the stand the front pad is odd the edge of the tubes. J&S says you have to remove the stand to use the jack. I'm not saying it dosen't work, I just want to know how you did it so I can try it on mine. Would make it so much easier.
heybaylor
May 20, 2018 07:59 AM
paid4c4
Mar 27, 2017 03:30 AM
mkguitar
Oct 28, 2016 05:21 AM
michaelmartin
Oct 1, 2010 01:20 PM
BIG Y 2014
Jun 18, 2009 07:49 AM
