discolored pipes
Old May 19, 2007 | 05:32 PM
kpb46's Avatar
kpb46
Default discolored pipes
Brand new ultra. 260 miles and the front pipe is tuned gold just past the front chrome shield (right by the floor board) Is this normal?? bike is bone stock
Old May 19, 2007 | 05:36 PM
jwmu's Avatar
jwmu
Default RE: discolored pipes
Yes. The run lean. I have an '07 Road Glide and it did the same. There are many threads on this forum that talk about this and some solutions - use the search feature.
Old May 19, 2007 | 06:10 PM
Dsanchez's Avatar
Dsanchez
My '07 EGC is purple between the heat shields. I've had 5 other HDs & none have blued like that but...who cares.
Old May 19, 2007 | 06:24 PM
HDJoe's Avatar
HDJoe
Its normal. Harley sells a heat sheild that covers that area. Its about $82. Its a shame that the bike does not come with it. Anyway I bought one and it looks great.
Old May 19, 2007 | 06:37 PM
jwmu's Avatar
jwmu
Not certain of this but...
Bluing may mean you are running hotter than gold (more lean). However, it could just be a matter of time. I've got 1375 miles on my '07 and it is just starting to turn blue.
My father has an '07 EG with more miles and his turned blue (stock with SE Slip-ons only).
I just added an SE Stage I a/c, the Stage I ECM Download, V&H Ovals and a V&H Fuelpak. I am keeping an eye on that section of pipe to see what happens. I also will dyno the bike next week to see the new air-to-fuel ratio from 0-6000rpm.
Old May 19, 2007 | 11:30 PM
kpb46's Avatar
kpb46
I was hoping to get thru the breakin without them turning. Havin Rinehart S/O's ..se air cleaner and Sert installed after breakin (and when they get the sert) then it will be dyno'd
Thanks
Old May 19, 2007 | 11:33 PM
bulldogmoe7's Avatar
bulldogmoe7
normal
Old May 20, 2007 | 01:58 AM
kpb46's Avatar
kpb46
Anyone use the Kury shield that fits btween the forward and rear stock shield. Lots less money
Old May 20, 2007 | 07:04 AM
badlandr's Avatar
badlandr
ORIGINAL: kpb46
What's the part number for that?
Old May 20, 2007 | 07:42 AM
PapaTravis's Avatar
PapaTravis
Kuryakyn sells what they call, 'Bridge the gap' heat shield. It is $29.99 and the part number is 9196. And it fits between the two existing sheilds. HD is $79.95, part number 65694-05A. It is a one piece that replaces the front sheild and butts up against the second sheild. Hope this helps.
