Lowering Front end Only
Old Jun 7, 2016 | 11:34 PM
OldPhat's Avatar
OldPhat
Putting 12 inch shocks on a RK Classic and lowering the front forks 1 inch, lowers the whole Bike.
Old Jun 8, 2016 | 09:01 AM
Sturgis67's Avatar
Sturgis67
Originally Posted by bagman1
Do you have spec numbers to back up your statement?
Nope, and don't need them. I ran the numbers for my own situation and was well within the acceptable range.
Figure out your own situation and run them yourself. There is a great deal of information and R&T calculators out there. Do a google search for rake and trail calculator.
Old Jun 8, 2016 | 09:02 AM
Sturgis67's Avatar
Sturgis67
Originally Posted by qtrracer
Go to RB Racing's rake and trail calculator. You'll see that lowering the front end 1" actually/only increases the trail .1". This must be due to the negative offset trees the touring bikes use.
And there you have it. Thanks QTR.
Here's another one
http://www.thompsonchoppers.com/rake...il-calculator/
Old Jun 8, 2016 | 09:04 AM
Sturgis67's Avatar
Sturgis67
That is correct, the question was if only 1 is lowered (originally front).
Old Jun 8, 2016 | 09:24 AM
KumaRide's Avatar
KumaRide
Here's another one
"Rake & Trail Calculator
WARNING: Still in development. Do not rely on measures for exact accuracy."
Old Jun 8, 2016 | 10:05 AM
2013superglideseattle's Avatar
Here's another one
TRAIL: The distance defined by the vertical line from axle to ground and the intersection of centerline of the steering neck and ground.
Is this how I read the trail measurements?
based on the diagram on the web, the trail has no effect when lowering just the front end?
The bikes rear end measurements are not even included on the Trails calculation. So why it is a must to lower bikes rear end when lowering front end? I dont need to do I? And bike is safe riding it that way.
By the way Thank you for this website.
Old Jun 8, 2016 | 10:16 AM
Sturgis67's Avatar
Sturgis67
That is correct, you shouldn't see any noticeable increase or decrease in handling with such small changes.
Not a problem, lots of useful web info out there
Old Jun 8, 2016 | 10:19 AM
Sturgis67's Avatar
Sturgis67
Yup, standard CYA legal statement. You can always verify, or use a different one.
Speaking of CYA. Don't take my word for it, verify the numbers for your individual situation. Viewer discretion is advised,
Old Jun 8, 2016 | 02:45 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
A little measuring with a tape measure and some quick math, you'll have the exact answer. As mentioned above, it's much ado about nothing.
Old Jun 10, 2016 | 01:02 AM
SnoRider's Avatar
SnoRider
I lowered my 2011 flhrc's front end 1.5" and it handled WAY better. much more responsive and controllable. No trail issues at high speed or fast acceleration.
DynaCaps9
Jul 6, 2018 04:35 PM
Mudfoot
Jan 15, 2016 03:03 PM
burnsy87
Jun 3, 2015 10:07 PM
smithbrl
Mar 20, 2011 02:12 PM
Pyatt5
Apr 24, 2007 05:41 PM
