Your bike has 1" wheel bearings, while the later 18" SG wheels use 25mm, however you can install 1" bearings in the later wheel. The simplest way to do that is to buy a bearing kit from H-D, which comes with the essential bearing spacer. I've done that myself on an older bike.
Your rotors will swap over to the later wheel, so you can continue to use your calipers. Alternatively you can use the later rotors and swap to later Brembo calipers, which will fit your forks. Later bikes use larger diameter rotors, hence the need to match them up, as they will not work with your current ones.
Will the later model Street Glide 18" front wheels and brake rotors fit the '07 bikes that came with a 16" front ?
Streetglide wheel is a 19,may have to change bearings and spacers
There is several on here that have done it.you can do a search on here and get part no that you need or you might go to part counter at Harley dealer and get everything you need
They should know or they might not
The classic SG style 18" wheel was fitted on from '08 to '13 - I have one on my old Glide! The current SG wheel went to 19" from '14, but is a different style.
