I just did about 40 miles give or take. It was a mixture of town/stop and go and a bit of highway. The beginning of the ride was just the same as before and I paid particular attention to how hard I was gripping and wrist position. By the end of the ride, I must say things smoothed out considerably and it was quite pleasant to ride. I'm sure time will be my guide as to whether or not it is still jumpy enough to warrant another solution, but for now I am sticking as is.
I'm so happy I put these bars on, and now it seems I'll be able to enjoy them.
One can adjust the Throttle Progressivity in the ECM through a tuner, but that wouldn't have any bearing on the mod you just did.
Ummm... most HDdealers don't seem to know about this... and V&H has 'progressive' throttle control built into their fuel pack. The problem with HD's design is that they aren't sampling enough and so the throttle over-reacts to quick movements... in other words, from 1-3 and you get thrown forward and backward with the road bumps on a stock harley... from a better algorithm that works like: 1, 1.5, 2, 2.5 you don't... unless of course you go all the way to 3 but you can adjust that with the fuel pack. I don't think spending $400 to fix a bad design (dangerous, actually) is fair. HD needs to re-do this concept but I'm pretty sure that they would have to replaced the BCM which they aren't going to do.
OP, is there any lateral movement (more than necessary) on the throttle grip, side to side. I ask because after a re install I did not get it on tight and found the same description you have. made it tighter and all good.
Mine is stock... so it had to come from the factory with this defect I think. Only different is that the LHCM and RHCM include police functions rather than what comes as stock and I don't think that the dealers set those up but I could be wrong...
I checked this. It did appear there was a lot of movement so I loosened everything and did the best I could pushing it on the bars a little further. Sure enough, it made a world of difference. There is still a slight amount of play and a bit of jumpiness to the throttle, so I will try again with my kid leaning on the end while I tighten the screws down.
Fingers crossed...
As far as resetting the system, no I didn't do that. I guess you need to if the wires are unplugged? Or is it if the fuse is removed?
I checked this. It did appear there was a lot of movement so I loosened everything and did the best I could pushing it on the bars a little further. Sure enough, it made a world of difference. There is still a slight amount of play and a bit of jumpiness to the throttle.........
That's what worked for me on a bike I had that had the same problem
SEPST can adjust the progressivity throughout the speed/RPM range. If it's set at a constant value across the board, ( say, setting at 100% [99] in all fields) you're gonna have problems. Low RPM needs a little "slack", a lower % to keep it from being over-sensitive at low speeds. Higher RPM, you want it "tighter", a higher % (99) for quick response when you're cruising at higher speeds.
Ummm... this isn't limited by the features of the ECM? If this is a common feature, why don't dealers think this is possible? How does it come from the factory? When does fixing this setting at lower speeds become part of the warranty? Are SEPST settings permanent or lost during a power loss? Please excuse my ignorance but I am only familiar with aftermarket tuners... one a piggy back and one an ECM.
I've had this problem on every bar replacement with TBW. Some were HD bars, others were aftermarket but always the same problem. For me it has more to do with how snug the grip is on the bar itself. On one set of bars I wrapped one layer of electrical tape on the bar and then slipped the grip over it. That added enough tension on the grip so it wasn't so sensitive without binding it up. But it only worked on that particular bar. On another set of bars I pulled the controls up the bar as far as I could. That helped to 'pull' the grip onto the bar and keep tension on it, that firmed it up. For some reason other bars were a lost cause and I learned to live with it. Very aggravating.
My grip was moving on and off the bar so I snugged it up as you suggested. It seems to be improved (I haven't hit the right kind of dip in the road yet). Thanks for the tip!
