Sputtering issues
Old Jun 24, 2016 | 08:45 PM
RoadKing1971's Avatar
RoadKing1971
6th Gear
Default Sputtering issues
Greetings everyone,
I have tried searching the forums for a solution but have not come across anything definitive. I have a 2007 FLHRC. Stage 1 air cleaner, V&H slip ons and a fuel pak. Last couple weeks have noticed my bike sputtering when taking off from a stop. Gets worse when it warms up. It smooths out some in the higher RPM's, Pulled plugs and looked good. Unplugged Fuelpak and runs the same. Installed new 10mm SE plug wires. No change. I decided to remove coil and test. I have a little over 6K ohms on the secondary circuit between the towers (May be the problem. dont know what the specs are yet). I need confirmation on testing the primary circuit. There are 4 pins. A-Power, B-Ion, C-Cyl front and D-Cyl rear. How should I check the primary circuit? I am leaning towards the CKP (have not tested yet) but wanna make sure before re-installing the coil.
Thank you very much
Old Jun 24, 2016 | 09:08 PM
dawg's Avatar
dawg
Clean or replace IAC stepper motor
Old Jun 24, 2016 | 09:16 PM
RoadKing1971
6th Gear
Will consider it. Thank you
Old Jun 24, 2016 | 09:18 PM
ORradtech's Avatar
ORradtech
Obviously not there to experience your symptoms but a stuttering issue sounds to me more like an fuel/air issue than a spark issue.
Old Jun 24, 2016 | 09:26 PM
leon anthony's Avatar
leon anthony
I see you only have two posts so you can not be expected to know who Dawg is but do as he say don't just consider it
Old Jun 24, 2016 | 09:45 PM
Teachinator's Avatar
Teachinator
Check the fuel lines in the tank. Those lines are notorious for developing pin hole leaks that can cause fuel starvation when you get past 1/2 a tank of fuel. When you turn te key to the on position you should hear the fuel pump charging the system. If you hear any gurgling sounds coming from inside the tank you may have a hole in one of your lines inside the tank causing fuel starvation.
Old Jun 24, 2016 | 10:41 PM
bdtaylor1979's Avatar
bdtaylor1979
Old Jun 24, 2016 | 10:49 PM
RoadKing1971
6th Gear
Good idea...Will check the fuel line tomorrow and report back...
Old Jun 25, 2016 | 07:20 AM
Florida Swamp Yankee's Avatar
Sounds like fuel more than anything else, similar thing wrecked Biketoberfest for me last year.
When was the last time the fuel filter was changed? If you have the means to check pressure coming out of the tank you should have better than 55psi...
Old Jun 25, 2016 | 07:46 AM
texaswiz's Avatar
texaswiz
Ya, that jumped out at me too. If you have not changed your fuel filter in the last couple of years, do so.
