Crankcase Vent By-Pass Mod - Opinions??
I dont understand how venting outside vs back into the throttle body could cause the umbrella flaps to flutter.
So this is a sincere question - I would like to know why a tiny amount of vapor going into the throttle body prevents fluttering umbrella flaps, while redirecting that outside does. Please explain what happens, exactly.
Hey Man, I cant answer it as I don't know either. Never claimed to know. Maybe it has to do with the suction from the intake?
When the pistons go back up to compress the air and fuel, they create just as much return air that sucks back into the valve cover. So you get a load of dirty air into valve cover.
Also, there is a small vent hole in bottom underneath the baffle box with the felt filter. Drilling this hole out only lets the air thru the baffle box blast thru from the bottom increasing the oil flow to the air box.
Thanks RIPSAW
OP here. Thanks for the replies and breather excerpts/info.
After viewing the breather info provided by ripsaw, I still don't see how any significant amount of air gets sucked in past the umbrella valve during piston upstroke, if the umbrella is in good, operating condition. I'm guessing any flutter in this valve is at best, momentary, when the pistons transition from downstroke to upstroke. I'm no expert in these motors by any stretch of the imagination, but unless there is some other air passageway effecting umbrella operation that I am unaware of, it doesn't seem likely that any significant amount of air is passing the umbrella during piston upstroke and hence allowing dirty contaminated external air from entering the crankcase. Again, all this given the proper operation of the umbrella.
With that said, it seems that the decision to vent crankcase air to atmosphere via an open tube or with a tube/filter, involves determining what is best overall for these motors. That being knowingly allowing dirty/oxygen-depleted crankcase air back into the throttle body, vs. trusting the integrity/operation of the umbrella valve and an external vent tube to effectively bypass the AC/throttle body. If taking the latter option of venting externally, I assume this requires another maintenance procedure of periodically checking external vent tubing for evidence of suction while the motor is running, and for evidence of discharge of condensation and possibly small amounts of oil from the crankcase. With no evidence of suction at the external vent tube, can one assume the umbrella valve is operating as designed, and that external air is not being sucked back into the motor via the external vent tube?? If that be the case, then there is little potential for engine damage related to the umbrella valve.
So, if the umbrella valve and external venting is operating as desired, I see the potential for more harm to the engine by allowing dirty, oily air into the intake, resulting in carbon/gummy pistons and valves vs. taking the decision to by-pass the AC and vent crankcase air elsewhere.
Again, I'm no expert, but I'm all ears if someone can provide physics-based or mechanical reasoning behind a preference for routing crankcase air back into the throttle body. I only want to do what's best for the longevity of my motor, given the cost of engine rebuilds.
Lastly, I will likely switch to a larger ID tubing for my crankcase venting, and perhaps attach a small filter to that tubing (for concerns of environment and umbrella valve failure).
Opinions/feedback welcome. Thanks all...
