Whining noise
Old Jul 13, 2016 | 10:25 PM
cdinsmore_16's Avatar
cdinsmore_16
Default Whining noise
I've got a 2003 flht and I've started to notice a slight whining noise, I thought at first it was my brakes or wheel bearing but I've noticed that it stops when i let off the throttle. the bike is tougher shifting and harder to get into neutral than it used to be not sure if it could be related.....my first thought is the main drive bearing, any ideas?
Old Jul 14, 2016 | 08:18 AM
Hate Work's Avatar
Hate Work
Whining noise? That is just the Mrs. when my honey-do list gets too long. Advice. Go for a long ride. Stop and have a festive beverage. Come home on time to take her to dinner. Whining should subside.
Old Jul 14, 2016 | 08:23 AM
Hate Work's Avatar
Hate Work
Check fluid levels. Is whining in all gears? Try to determine how much load is causing the noise. Bearing? Possible. Go through the logical progreesion.
Old Jul 14, 2016 | 08:53 AM
cdinsmore_16
fluids are good, it does whine in all gears and doesn't matter if I give it just a little throttle or a lot the whine is the same....when I'm stopped and rev it up or let it idle it doesn't do it. only seems to be when moving
Old Jul 14, 2016 | 08:56 AM
roundy's Avatar
roundy
First thing is to check the primary chain tension, eliminate that first. Incorrectly adjusted primary chain would causes issue changing gear, finding neutral and whine.
Old Jul 14, 2016 | 08:58 AM
racersmomma16H's Avatar
racersmomma16H
Kick her off the back! She obviously doesn't like to ride. jk Hope it isn't anything major.
Old Jul 14, 2016 | 11:43 AM
Geoff's Avatar
Geoff
Good one!
Old Jul 14, 2016 | 12:32 PM
bdtaylor1979's Avatar
bdtaylor1979
Maybe check your primary fluid and adjust the chain if you can.
Old Jul 14, 2016 | 03:28 PM
hardheaded's Avatar
hardheaded
does it do it with the engine off and just rolling it ? in gear or not ?
Old Jul 14, 2016 | 06:35 PM
Retrop's Avatar
Retrop
First thing I would look at would be the tension on your primary chain, inside the primary case on the left side.
Second thing that might be whining might be the final drive bearing in the transmission. This is the bearing behind the pulley that drives the belt that goes to the rear wheel.
I hope it is the first but the second thing is pretty common especially since people started putting really heavy fluids in their transmissions.
