expert mechanic needed...HELP!
Old May 21, 2007 | 09:25 PM
floridian46's Avatar
floridian46
Default expert mechanic needed...HELP!
ive got my 07 flht to roadking conversion just about buttoned up...the bad news, it wont start!..it doesnt appear to be pumping gas...when i disconnect the quick fuel line disconnect, its dry...the starter turns over, but no fire...when i turn on the key, i dont hear the fuel pump, until i turn the ignition off and then i just hear a quick flutter coming from the tank..
i have followed the service manual as far as the the handlebar wiring...
is it possible that its not getting fuel because the tank was dry and its a new fuel pump??HELP!!!!
Old May 21, 2007 | 09:34 PM
gman's Avatar
gman
Default RE: expert mechanic needed...HELP!
did you check all your fuzes to see if you have a blown one? if you can't hear the fuel pump when you turn the ign on, probably you aren't getting any power to it.
Old May 21, 2007 | 09:37 PM
anubisss's Avatar
anubisss
New fuse should take care of it hopefully...
Old May 21, 2007 | 09:38 PM
choochoo's Avatar
choochoo
Not likely. It's a self priming system. Unless a line is plugged.
You almost definitely have a wire harness plug connected wrong or not connected at all.
Perhaps a blown fuse.
question is though if you wanted a road king so bad why didn't you just buy one in the first place?
Nothing that complicated is ever a direct swap.
But good luck
Old May 21, 2007 | 10:14 PM
floridian46
answer: the dealer wanted 5 grand to trade and i couldnt live with the flht any longer. i was already upside down on what i owed bigtime..trading wasnt an option....
Old May 21, 2007 | 10:18 PM
floridian46
the only thing that was a bolt on, was the handlebar switches...i had to go by the service manual and splice in some switches from an 05 model..the partsbook show that they fit the 07s, but a couple of wires were a different color than the 07 harness..
the fuel pump fuse is intact...
yarddog6082
Jan 18, 2018 09:41 AM
PapaFunk
Jul 26, 2017 11:36 AM
Nightcruiser
Jan 10, 2015 11:26 PM
psusarah
Audio Systems
Dec 11, 2014 05:58 AM
jaycruiser
Exhaust System Topics
Mar 14, 2009 09:10 AM
