Wirng Problem?
Old Jul 26, 2017 | 08:19 AM
PapaFunk's Avatar
PapaFunk
Stage II
Default Wirng Problem?
Good morning! I am new here! I have a 2008 HD Road King that I installed Monkey Bars. The bike was running and operating great when I pulled it in the garage. Bought the extension wire kit. Made all connections. Soldered, and shrink wrap. All lights come on like they should. Turn kill switch on. Can hear the fuel pump energize. It will turn over, but will not fire. Sprayed a little starter fluid in it and it will fire till fluid is gone. Any suggestions?
Old Jul 26, 2017 | 09:23 AM
Buelligan666's Avatar
Buelligan666
Did you take the tank off? Reconnect fuel line? If it's the quick connect, you may not have got it seated correctly.
Old Jul 26, 2017 | 10:34 AM
PapaFunk's Avatar
PapaFunk
Stage II
No, did not remove tank. But thanks for the reply!
Old Jul 26, 2017 | 11:36 AM
longrideshields-2's Avatar
longrideshields-2
Premium Sponsor
I would double check the wires you worked with that are shown in this wiring diagram 1st... Make sure the fuel pump is sending fuel into the F I system. If not, you may have a clogged fuel filter.
It is very frustrating that you do a wiring job, and then a fuel delivery problem appears.
__________________
LONG RIDE SHIELDS
www.longrideshields.com
Nightcruiser
Jan 10, 2015 11:26 PM
kballowe
Jun 25, 2012 10:25 AM
mikael
Jun 23, 2010 12:35 AM
jaycruiser
Exhaust System Topics
Mar 14, 2009 09:10 AM
floridian46
May 21, 2007 10:18 PM
