Ultra classic
Old Jul 18, 2016 | 09:53 AM
Giantfan256@yahoo.com's Avatar
Stage III
Default Ultra classic
Having an issue with the throttle control on my 08 Electra glide ultra classic. Sometimes it goes into limp mode.
Old Jul 18, 2016 | 06:57 PM
14GuineaPig's Avatar
14GuineaPig
This might interest you. Check for codes.
http://www.motor-talk.de/forum/aktio...hmentId=740526
Old Jul 18, 2016 | 08:44 PM
wscott's Avatar
wscott
Had the same issue on my 09 FLHTCU that was a combined fretting/wear/corrosion issue within the connector located
behind the air cleaner that plugs onto the throttle body
so chk that out.
HD makes a retrofit kit to address that issue.
Scott
Old Jul 24, 2016 | 09:10 AM
leachman's Avatar
leachman
I had this happen on my way to Myrtle Beach. rolled into Myrtle Beach HD and they took care of me right away....Very good dealership by the way. Turns out the fly by wire throttle control sleeve was bad. Bike was throwing codes off and on all the way to myrtle from CT. So either change that or take it to your dealer cause like me if you carry a warranty its worth the $50 you'll spend.
Old Jul 24, 2016 | 09:12 AM
Iceman24's Avatar
Iceman24
And...welcome!
Old Jul 24, 2016 | 11:06 AM
Joker58's Avatar
Joker58
6th Gear
Anyone have a wiring diagram for the right side handle bar controls? My radio is stuck on Aux
Old Jul 24, 2016 | 12:26 PM
bdtaylor1979's Avatar
bdtaylor1979
That happened to mine 4-5 years ago and the dealer replaced the twist grip sensor under warranty. Had some codes pop up last summer for the throttle by wire, cleaned the connector on the side of the throttle body behind the air intake and the codes haven't come back since. I would start with cleaning the connector on the throttle body first. You can get electrical contact cleaner at a auto parts store. Cheaper and easier than replacing the twist grip sensor unless your bike has a extended warranty.
Old Sep 10, 2016 | 04:28 PM
Joker58's Avatar
Joker58
6th Gear
Default 2010 Ultra Classic radio issues
My Ultra classic radio will not switch off the aux? Anyone know what I can try to get it back to the radio?
Old Sep 10, 2016 | 04:39 PM
Joker58's Avatar
Joker58
6th Gear
any one have a wiring diagram for the right side handle bar radio controls? 2010 Ultra classic . My right side handle bar controls are not working.
Randy La Rose
Jun 1, 2016 05:13 AM
beamernc
Jan 10, 2013 05:39 PM
Dallastx
Apr 29, 2012 03:13 PM
05Hog
Jul 4, 2011 09:09 AM
baddog1200c
Apr 24, 2008 08:28 PM
