2001 FLHRI , injectors quit working- HELP
Old Jul 19, 2016 | 07:29 PM
NkBignKFFK's Avatar
NkBignKFFK
Stage II
Angry 2001 FLHRI , injectors quit working- HELP
Here's the story. My bike has run perfect since the day I got it 4 years ago. I noticed it was stumbling at mid range, so I checked the intake gaskets, sprayed some carb cleaner on both and the bike died. So I installed new intake gaskets. Keep in mind I did not disconnect any electrical connectors on the EFi system. I unplugged the fuel pump, the gas gauge and the horn. I removed the tank and the horn, to get better access. Installed the new gaskets, ensuring I had the front and rear flanges in the correct spot. Put everything back together and now the Injectors are not shooting fuel. All fuses are good, I ohm'd every wire in the EFI harness, all good. And battery is fully charged. Everything on the bike works, except the injectors. I am showing no codes on the speedo and when I check for codes on the "check engine light", it flashes 14 times over and over, without a break in the 14 flashes. Help!
Old Jul 19, 2016 | 08:12 PM
Bill03E's Avatar
Bill03E
Fuel line quick disconnect? Take it off ,and put it back on.
Old Jul 19, 2016 | 08:21 PM
NkBignKFFK's Avatar
NkBignKFFK
Stage II
I have done that, I have pressurized fuel in the supply line
Old Jul 19, 2016 | 10:53 PM
Bill03E's Avatar
Bill03E
I am sorry , I got nothing at the moment. I will have to think about this one.
Maybe someone else has an idea.
Old Jul 20, 2016 | 07:59 AM
Bodean46's Avatar
Bodean46
When I changed my injectors on my 01, I inadvertently switched the fuel connections on the tank. Couldn't figure out why no fuel to injectors, till I looked at a breakdown of the entire system. reversed lines and it fired. Just a thought.
Seattle96Rk
EVO
13
Jul 5, 2016 11:49 AM
Moondogger
Jul 4, 2013 03:41 PM
IowaRandy
May 8, 2013 12:44 PM
skim1420
Exhaust System Topics
Nov 5, 2011 01:14 PM
nazareth27
Apr 3, 2010 07:25 PM
