Front wheel spacers
Old Jul 20, 2016 | 04:32 AM
wks_13's Avatar
wks_13
Default Front wheel spacers
Hi all, I have a 2009 Road king with abs would anyone know what length the internal hub spacer and the one external spacer is
TIA
Bill
Old Jul 25, 2016 | 08:46 AM
multihdrdr's Avatar
multihdrdr
Still lookin' ?
Old Jul 26, 2016 | 03:59 PM
wks_13's Avatar
wks_13
Hi, have found a old post and it looks like the outer spacer are all the same. The reason i asked is i had a new tyre fitted and the non abs bearing felt a bit ruff so had new bearings fitted. The fitter found that the non abs bearing was a 1inch instead of a 25mm bearing. The inch bearing is approx 6mm wider. Have fitted wheel and seems ok but wanted to be safe and ask. On a side note am now waiting on a new wheel, the old wheel was corroded around valve and leaking. Asked for a new valve as well?????. It was fitted by a dealer!!!!!!!!!!
TIA
Bill
Old Jul 26, 2016 | 04:38 PM
multihdrdr's Avatar
multihdrdr
Hmm...that was hard for me to follow
Are you saying you found a 1"x21mm wide bearing installed and now changed back to a 25mm x 15mm wide on Non-Abs side?
Old Jul 26, 2016 | 04:49 PM
wks_13's Avatar
wks_13
HI, Thats correct, had the proper bearings fitted. Axle shaft fitted ok. With the non abs bearing "floating" was wondering weather the legs were being pushed apart with the inch bearing or pulled in with the metric bearing
TIA
Bill
Old Jul 26, 2016 | 06:01 PM
multihdrdr's Avatar
multihdrdr
Unless someone made a custom axle spacer and/or center spacer sleeve to accommodate that extra 6mm bearing width, then yes, it would have spread the legs.
You should be using the original 1.012" spacer against the 25mm x 15mm wide bearing.
Did the 1" x21mm bearing protrude? It should have. If not, then the center spacer sleeve was modified.
Old Jul 27, 2016 | 04:22 AM
wks_13's Avatar
wks_13
Thanks for the reply. Have got to pick up new wheel today. Will strip old wheel and measure and report. Cheers
Bill
Old Jul 27, 2016 | 04:21 PM
wks_13's Avatar
wks_13
Hi puller broke so measured bearing to bearing at 165mm. Measured a new sleeve at 132mm with the abs bearing at 18mm and non abs bearing at 15mm that comes out the same. so hopefully fit new bearings and good to go. Outer sleeve also measured at 1.012". thanks for the info
Bill
Old Jul 27, 2016 | 04:36 PM
multihdrdr's Avatar
multihdrdr
~165.72mm (18 + ~132.72mm + 15)
and
1.012" (25.70mm)
Looks good.
BTW, Make sure you install the first bearing in the "Primary" side (left side of Front wheel). Indicated by the machined groove in the rotor mounting surface (seen if rotors are off.)
Last edited by multihdrdr; Jul 27, 2016 at 07:17 PM. Reason: edited one Dimension...my bad
Old Jul 28, 2016 | 04:24 AM
wks_13's Avatar
wks_13
Thanks again for your help much appreciated
Bill
Kugie's HOG
2014-2024 Touring Models
103
Jun 19, 2017 09:36 PM
Northside
69
May 7, 2017 10:58 AM
Keithhu
Mar 11, 2012 03:56 PM
itsmf
Dec 26, 2011 10:17 AM
ten09
Jan 27, 2010 11:46 PM
