Whoa!
Old Jul 28, 2016 | 07:43 AM
  #51
THE PEG's Avatar
THE PEG
That tire had little life when you left. Remember if you are taking a trip and the tires are borderline change them. Why spend time on the trip getting them changed? You're a lucky man.
Old Jul 28, 2016 | 08:07 AM
  #52
Prologix's Avatar
Prologix
So you have first hand experience that when neglected the Metz held together and delivered you home safely. Not I understand that that knowledge applies specifically to your bike and your riding style. Why on earth would you not stick with that kind of security?
On an other note the 888's are the go to tire for Suzuki Boulevards I used them no complaints. (Lighter bike though)
Old Jul 28, 2016 | 10:16 AM
  #53
dugan's Avatar
dugan
That's a viable question, however, I'd like to see if I can get more miles out of a tire than 8-10,000. Granted the Metz held together, and I rode it probably harder than I should have on that trip (which I never do) but now I want to see what the MC II can do mileage wise.
Old Jul 28, 2016 | 10:55 AM
  #54
bettingpython's Avatar
bettingpython
What was your tread depth measurement before you left? I'm betting you don't know, it was probably already below the minimum safe limit before you left. You neglected to to properly check and maintain your tires and are blaming it on the brand.
At just shy of 8000 miles on an Avon Cobra rear I have a little under 2/32" of tread depth in the center, when I left for a 2000 mile Colorado ride I had 4/32" of an inch left. As the wear depth increases the rate of wear increases as well that;s why you change your tires at 2/32"
Old Jul 28, 2016 | 11:13 AM
  #55
stevenh's Avatar
stevenh
i had the same tire's on my 09 street glide. i got 5k on the back and it looked like yours. also was told the mII's might rub. some bikes they do and some don't. i ordered anyway and mine doesn't. already have 3k on the MII's and they still look new. i know it was a expensive gamble, but i wasn't going back with the metz.
Old Jul 30, 2016 | 12:32 AM
  #56
Ben E's Avatar
Ben E
Same thing happened after 9,000 on Metz with me.
Old Jul 30, 2016 | 03:46 AM
  #57
Jrsess's Avatar
Jrsess
Bottom line you need a tire. The brand is your choice! JR
Old Jul 30, 2016 | 11:45 AM
  #58
dugan's Avatar
dugan
A new Michelin Commander II was mounted this morning. It was a tight fit but I like it tight. Now a few more miles on the front tire and it will be replaced with a MCII as well. The Metz held up enough for me to ride it to my local Indy but in the future i will be checking my tires more thoroughly. A chill still goes down my spine after realizing after the fact how worn the Metz was and riding it that far.
IrIeSpringer420
Mar 1, 2015 06:39 PM
The painter
Oct 1, 2012 08:48 AM
BadX
Jul 30, 2007 02:57 AM
BGHV65
Jun 25, 2007 01:50 PM
jd_underdog
Jul 7, 2006 06:24 PM
