Changing handle bars
Old Jan 22, 2005 | 02:45 PM
Col Fod's Avatar
Col Fod
Stage II
Default Changing handle bars
I admired a set of heritage softtail handle bars on a friend's road king. The dealer had swapped his out for him. Can anyone walk me through the procedure? HD says my cables will all fit and I would like to try to do it myself...being somewhat mechanically minded.
Jim
Sorry, forgot: I have an 03 Road King Classic.
Old Jan 22, 2005 | 07:02 PM
luvmyflhtcui's Avatar
luvmyflhtcui
Default RE: Changing handle bars
Measure your cables and also the cables of the bike the bars are coming off of. Changing out the handlebars is very easy. The harderst part id removing your old grips and installing them on the new bars. You have to sand and prep the bars for the glueing on of the left grip. The wiring is all on the outside of the bars and the clips are very easy to install. Make sure that you have free clearance for all cables and that they do not bind and you will be in there.
Good luck,
Scott
Old Jan 22, 2005 | 09:06 PM
billnourse's Avatar
billnourse
On the Road King, you have to remove the Headlight and and the cover on top of the Nacelle to get to the handle bar clamp. My suggestion is to get a shop manual for about 57.00, and you will have step by step instructions. If you are mechanical, you will probably want to do other maintainance, repairs, changes, etc, so the manual will be a good investment.
Just a thought.
Regards,
Bill
Old Jan 22, 2005 | 10:36 PM
Sincecrazy's Avatar
Sincecrazy
To remove the bars youll have to remove the handlebar clamp cover, to expose the handlebar clamp. There is a trim ring around the fork lock cylinder that simply pops up, slight use of a flat head screw driver will work. Youll have to remove the screw under it for the cover removal. Remove the headlight trim ring and the headlight assembly to expose the nut that holds the slim chrome cover on top of the headlight nacelle, after removing the nut you can lift up on the front and pull toward the front of the motorcycle to remove the trim. After removing the trim you will see the bolt that holds the handlebar clamp cover to the headlight nacelle, remove this and the cover should lift off. Remove the 4 bolts holding the handlebars and you should be able to lift them off. I would recommend covering your tank should you drop a wrench or the bars on the tank. Remove your controls and grips before removing the bars. You can easily remove the left grip using a thin bladed screwdriver in which you want to push under the grip and spray some carburetor cleaner under the grip, then twist. Good luck, and if you have any questions feel free to ask.
Old Jan 23, 2005 | 12:14 PM
Col Fod's Avatar
Col Fod
Stage II
Thanks to everyone--I'll go to the dealer today (open Sunday afternoons), get the manual and get started. I am moving from Georgia to Oklahoma soon and cannot wait for the cruise back west.
Old Jan 23, 2005 | 09:53 PM
05roadking's Avatar
05roadking
Hey sincecrazy, was there a lot of work involved with putting those ape hangers on your RK? I assume ya had to get different length cables all round....?
Old Jan 23, 2005 | 10:54 PM
05roadking's Avatar
05roadking
just saw what you did in another post so.......NEVERMIND!!!![sm=icon_quiet.gif]
Old Jan 27, 2005 | 02:55 AM
ApeKing's Avatar
ApeKing
ORIGINAL: Col Fod
Umm no offense but ewww why would anyone leave GA for OK?! Im near Atlanta and me and the wife visit her folks in Euflala Oklahoma every christmas. Not my cup o tea for SURE! the best thing about OK is no helmet law!
Old Jan 27, 2005 | 10:10 PM
pococj's Avatar
pococj
ORIGINAL: ApeKing
ORIGINAL: Col Fod
Next time you come this direction from GA, aim for the southeastern part of OK. Beautiful riding country there and in neighboring Arkansas. Try the Talimena Highway near Mena, AR and heading over into OK.
Old Jan 27, 2005 | 11:42 PM
Sincecrazy's Avatar
Sincecrazy
ORIGINAL: 05roadking
Yeah, there is alot of work in it. All the cables have to be replaces with longer ones. The wires have to be extended and ran internally in the bars. All of the exhaust had to come off to replace the clutch cable(if only the clutch cover would have been in a different place). Brakes had to be bled. Its involved, but I love the results.
sealbeachbum
Oct 3, 2012 11:58 PM
mikelikesbikes
Sep 15, 2012 12:16 PM
Dans03RKC
Sep 7, 2010 06:25 AM
drummond
Jan 10, 2008 07:37 PM
Hdbiker1450
Feb 28, 2007 11:05 PM
