Better Lever?
Old Jan 25, 2021 | 05:48 PM
John Bennett's Avatar
John Bennett
Stage I
Default Better lever
I have 93 softail used a dremel to cut off old lever then use dremel to sharpen spline on trans shaft and on the new btr lvr . Had to modify new lever as it clamps down like the stock one only in the front, if you cut down the back 1/8 of an inch so the top of the new lever sits flat on ur work bench this way when you put it in it will compress on the trans spline equally . I could not get it to get tight enough on the spline until i trim the back down.
Old Jan 25, 2021 | 06:42 PM
CGLTD's Avatar
CGLTD
Wow, a blast from the past!
sbbrown
Apr 5, 2019 12:34 AM
TSheff
Jan 19, 2017 02:38 PM
bluharley
EVO
Jun 9, 2013 12:10 AM
Robtarra39
Oct 22, 2011 08:36 PM
trivas1
Jul 28, 2010 09:50 PM
