Rider backrest: difference between adjustable and non-adjustable
Old Aug 4, 2016 | 05:51 PM
YPD485's Avatar
YPD485
Originally Posted by Mister Breeze
To each his own....
I've owned both and prefer the non adjustable. Once you have it set, it's fine. Easier to remove I thought too. My adjustable was a pain to get it off at times.
Plenty of them out there too. Bought my last one on eBay for $80 like new. Everything included.
I also tried both on my 2014 Limited. All the adjustable backrest did when adjusting it was to press way to much into my back. So I could only use it in the full rearward position. Then I got a CVO heated seat and the adjustable backrest pressed to hard into the leather of the seat to where it would eventually tear the leather.
So I removed the adjustable and now have the fixed backrest which is comfortable and doesn't damage the seat. Now I see why the CVO bikes only come with the fixed backrest and not the adjustable backrest.
Old Aug 4, 2016 | 07:14 PM
Steady Eddy's Avatar
Steady Eddy
I bought the non-adjustable for my RK with a Hammock seat. It didn't allow me to lean back enough (I'm 6'2"). Took it back to the dealer, bit the bullet and got the adjustable version. Perfect. Rarely adjust it, but did a couple of times on the trip to Sturgis. Definitely the adjustable one if you need more room.
Old Aug 4, 2016 | 07:47 PM
crazytown's Avatar
crazytown
I have the adjustable on my RK. I rarely re-position it during commutes, but will adjust a few times on long rides. I love it, rarely ride without it.
FWIW I kept a watch on the 'Touring Parts for sale' thread, and bought mine from another Forum member. Win-Win for both of us.
Old Aug 4, 2016 | 08:03 PM
EricD10563's Avatar
EricD10563
I have the adjustable and adjust it fairly often while on a road trip. Sometimes I like it to push me a little forward other times I push it back like it's not really there. Once you know where the lever is it's really easy to do on the fly. Me I'd rather be able to adjust it and not need it than not be able too.
Old Aug 4, 2016 | 08:11 PM
SC_Compact's Avatar
SC_Compact
Have you considered Kuryakyn Plug-In Driver Backrest - 1670. I picked one up on Ebay and I am very pleased with it.
There is a good vid on Youtube on it ==>
Old Aug 4, 2016 | 09:55 PM
jberg's Avatar
jberg
The adjustable unit's gas shock has a slight cushioning effect adding to its comfort where the non-adjustable is rock solid.
Old Aug 5, 2016 | 01:37 AM
valpal's Avatar
valpal
EXCELLENT input @ALL you guys! Thanks so much. As I dare to say that I would shell out the money for the adjustable one (just cringe at the thought) I am also one who likes to have choice, even though later on I might not be making use of that choice. Then again, buying something where you're "stuck" is annoying if you realize that you'd need some adjustment. Literally. And I do ride long stretches, so I am indeed changing the seating position here and there. So I guess I'll go the route of adjustable as I do not have a CVO. The Kury one looks good too but that is not adjustable from the looks of it, so I'll go with the MoCo adjustable one. I will probably have spent my money less wise than that... Thanks again! Much appreciated.
Old Aug 5, 2016 | 08:05 AM
Super08's Avatar
Super08
There is a good vid on Youtube on it ==>Kuryakyn Plug-In Driver Backrest Harley Davidson Street Glide Special - YouTube
That is what I ended up with. I had the HD non adjustable one but could not get it in a position I was happy with. It pushed me forward too much. The Kuryakyn backrest is manually adjustable (seat has to be off). Some don't like that it doesn't fold down for getting on or off the bike, but that is a non issue for me. I really like it.
Old Aug 5, 2016 | 03:05 PM
470004's Avatar
470004
I have both one on each bikes. On the adjustable rider backrest, I had never re adjust it since it was installed.
Old Aug 5, 2016 | 03:13 PM
Handyman163's Avatar
Handyman163
2nd Gear
Mustang makes one that is adjustable with a thumb-screw. You can adjust how much it pushes against your back by reaching behind you while you ride. Height is only adjustable when you stop, but at $215, it sure comes in right on price. I have one and love it. Installs under any Harley touring seat with the slot cut out for a backrest. Compared to the Kuryakyn, it was worth the extra $60 to have adjustability and the ability to fold down flat to aid in swinging a leg over or letting passengers on/off.
"Mustang Driver Backrest Kit"
