Chirp when downshifting 2007 RKC
Old Aug 15, 2016 | 03:15 PM
RonaldL's Avatar
RonaldL
Default Chirp when downshifting 2007 RKC
Get a single chirp when downshifting. Sounds like a belt or tire would sound if it slipped a little. Anyone know what it may be ?
Old Aug 15, 2016 | 04:14 PM
Roadflyer's Avatar
Roadflyer
Maybe a belt or a tire?
Old Aug 15, 2016 | 04:17 PM
Neil's Avatar
Neil
Check your belt tension. I noticed when mine was a little loose it would chrip a little. It got worse when wet.
Neil
RDMC
Old Aug 15, 2016 | 05:03 PM
turdlefxst's Avatar
turdlefxst
Check the rear wheel sprocket. If its not shiney, and the coating is coming off. That will make it chip also...........
Old Aug 15, 2016 | 05:50 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
most likely, rubber muffler hangers, next motor mounts, then look at ids.
Old Aug 15, 2016 | 06:19 PM
Buelligan666's Avatar
Buelligan666
Match your rpms to your gear by blipping the throttle. Chirping the back tire isn't good for your compensator or bottom end.
Old Aug 15, 2016 | 06:27 PM
mrmud4x4's Avatar
mrmud4x4
Plus 1 on the muffler mounts....
RK_RIDER
Aug 15, 2011 11:02 AM
kbrain
Feb 27, 2011 01:07 PM
escherWG
May 1, 2010 07:52 AM
TexFordD
Nov 24, 2009 05:24 AM
ricktara
Aug 2, 2009 02:12 PM
