Fp3
Old Aug 18, 2016 | 12:40 PM
rusty289's Avatar
rusty289
Default Fp3
About to order an FP3 for my 2015 Road Glide Special.
Who's using one out there? Are they as good as I think they are?
Any issues with removing it for warranty? (If anyone has needed to)
Vance and Hines says it leaves no trace when the stock map is reloaded and the tuner is removed.
Thoughts?
Thanks all!
Old Aug 18, 2016 | 12:52 PM
JOECAKRON's Avatar
JOECAKRON
I just ordered mine from directcycleparts.com. On sale for $100 off! Putting it on this weekend.
Old Aug 18, 2016 | 12:57 PM
rusty289's Avatar
rusty289
Same place I am going to order mine from, best price I could find anywhere!
www.directcycleparts.com
Old Aug 18, 2016 | 03:09 PM
HDRoadking_nc's Avatar
HDRoadking_nc
Love mine, very easy to install and use and you can remove it after flashing if you don't want to have it on the bike. I keep mine installed all the time so I can see all the stats on the smartphone app connected via bluetooth.
Old Aug 18, 2016 | 03:34 PM
bdtaylor1979's Avatar
bdtaylor1979
If they are as good as the previous fuel paks, should be worth it. I put a older version on mine because it's a 09 and they hadn't come out with the fp3 yet. It gave a little more performance and reduced the heat from the engine. If you need to take the bike in for warranty work, all you should have to do is return the map back to stock and remove the module from the bike and they shouldn't be able to tell it was on there. But I've had my bike in for warranty work a few times and they never said anything about the fuelpak. If I ever get a newer bike, I will put a fp3 on it unless there is already a tuner on it.
Old Aug 18, 2016 | 03:41 PM
mibeaulieu's Avatar
mibeaulieu
Simply put - it's fantastic. The bike runs great. Load a map, run a couple auto tune sessions and you're done. The perfect solution for stage one upgrades.
Old Aug 18, 2016 | 03:48 PM
BigDawgQC's Avatar
BigDawgQC
Great product. Mine works terrific.
Old Aug 18, 2016 | 03:51 PM
Tall Mike's Avatar
Tall Mike
I'm happy with mine the bike runs better than it did with the SE tuner the dealer had installed before I bought the bike..
Pretty simple to use which is a bonus for us technology challenged riders...
Old Aug 18, 2016 | 04:11 PM
ElectraJim's Avatar
ElectraJim
I've been considering purchasing one of these, but, I just noticed a disclaimer on the Vance and Hines website that states, "NOT LEGAL FOR SALE OR USE IN CALIFORNIA ON ANY POLLUTION CONTROLLED MOTOR VEHICLES"
Ummm... now what?
Old Aug 18, 2016 | 04:42 PM
Jr.Bean's Avatar
Jr.Bean
6th Gear
Thoughts?
Thanks all!
I had mine put on at last year's Daytona Biketoberfest. Although it made an immediate small difference, it really started shining when I stopped at a dealer on the way home to Illinois and had my stock headers replaced with power duals! One word of warning: The initial flash from FP3 (before you autotune) may result in the bike being easy to kill at low rpm's. A quick 20-30 minute autotune session will fix that and make the bike run great. Do Not Autotune much longer than that! It will result in a much more sluggish map!
Do it!
