Need help picking mini-Apes
Old Aug 23, 2016 | 07:25 PM
striper.seeker's Avatar
striper.seeker
Default Need help picking mini-Apes
I want to swap out the stock handlebars for mini-apes. 10" is fine. What I need is a more straightened hand position. What I mean is parallel to the fairing or 90-degrees out from the tank. It's hard to find a lot of bikes around here to try out. I've been to a few rallys but no luck.
Can anyone that has swapped out theirs let me know how the wrist position is?
Thanks
Mark
Old Aug 23, 2016 | 07:42 PM
bgdv1's Avatar
bgdv1
Need help picking mini-Apes-20150324_145857_resized.jpg LA Chopper 10" bagger bars. stock wiring and cables.
Old Aug 23, 2016 | 07:45 PM
striper.seeker
They look pretty good. Is the picture pretty accurate? The grips look pretty straight.
Thanks!
Old Aug 23, 2016 | 08:02 PM
lefty33's Avatar
lefty33
I just changed out my bars this past winter. Went with the 1.25" Khrome Werks 10" Bobber Bagger Apes. Chose these for the same reason...they have a "flatter" wrist angle (hands more parallel to the fairing). Very happy with my decision...plus they look so much better than stock being 1.25" diameter and internally wired.
Check them out...http://www.khromewerks.com/Bobber-Apes-1065-654-1.html
Old Aug 24, 2016 | 04:13 AM
Dguy's Avatar
Dguy
I went with 8" Twin Peaks for the same reason. I didn't want higher just a more turned hand position.....turned out exactly as I hoped. You will be happy with the 10" if you just want a more "turned out instead of back" wrist position.
Old Aug 24, 2016 | 06:40 AM
Jasmine2016's Avatar
Jasmine2016
Default Apes
Thanks
Mark
I JUST installed a set on my stepsons 2012 streetglide 14 inchers. I didn't really care for the wrist position.or the arm for that matter. but its not my machine so tra la la.Make sure to do your research before install. They are a bitch to install.Harley gets big $$$ I hear around a g. Not a do it yourselfer. I do all my own upgrades from pipes to motors etc. It took a real 6.5 hours . Not fun .. Be prepared to pay.
Old Aug 24, 2016 | 10:37 AM
Joe12RK's Avatar
Joe12RK
2009-up Heritage Softails have mini apes - not to be confused with the 'heritage' bars that came on them forever before then. I found them very comfortable on that bike.
Old Aug 25, 2016 | 04:58 PM
TXNT's Avatar
TXNT
I sat on a 2016 SG at the dealership that had the Harley Mini Apes on it. I did not choose them because they were to parallel to the fairing and seemed very uncomfortable to me. You might give them a try and see if they work for you.
Good Luck
Chrome Batwing Mini-Ape Handlebar
Part Number 57474-11
http://www.harley-davidson.com/store...-ape-handlebar
Old Aug 25, 2016 | 05:22 PM
bbissell's Avatar
bbissell
I just had these installed yesterday. Todd's Cycle 10 inch only one short ride home today but very comfy.
Old Aug 25, 2016 | 08:14 PM
Beaux's Avatar
Beaux
Wild One Chubby 10" WO578's ................... the LA Choppers are great bars too, buddy has them!
