Getting slip on mufflers back on?
Old Aug 24, 2016 | 09:56 AM
Aces and 8s's Avatar
Aces and 8s
Had many a slip on on and off. Never really had any issues. Sometimes it can be a PITA to get going, but a little wiggle and a push and they slide right back on.
Old Aug 24, 2016 | 11:53 AM
bagman1's Avatar
bagman1
Never seeze, wd 40 may get it on but it will burn off and wont be of any assist next time you remove them. If you cant spread the ends or get an expander either use a large ball peen hammer (ball end) and tap the end tabs out. When you clamp it down will flatten out the spread ends.
Old Aug 24, 2016 | 12:00 PM
steelerdude1's Avatar
steelerdude1
Luring it up won't hurt anything, it will just smoke for a little while until it burns off. With that said, lube it up and twist back and forth while pushing it on. It sometimes helps to jiggle it up and down while pushing as well.
Old Aug 24, 2016 | 12:05 PM
Nute's Avatar
Nute
High Temperature Silicone. Helps to lubricate while wet and seal when dry.
Old Aug 24, 2016 | 12:37 PM
bdtaylor1979's Avatar
bdtaylor1979
I've Heard that you can put antisieze on the end of the head pipe where the mufflers slide on and it helps them slide on easier and are supposed to come off easier next time.
Old Aug 24, 2016 | 12:57 PM
CanonSterVA's Avatar
CanonSterVA
Get a pipe expander...
http://www.harborfreight.com/automot...der-69548.html
ISP-FLHTK
11
Feb 27, 2017 04:07 PM
Notgrownup
Exhaust System Topics
Dec 2, 2015 07:02 PM
Moneywoes
Aug 17, 2015 04:28 PM
Stonewall69
Mar 31, 2013 09:08 AM
gilmour68
Feb 20, 2009 08:44 PM
